SV: [mapserver-users] Newbie feedback
Steve Lime
Steve.Lime at dnr.state.mn.us
Wed Aug 12 13:03:07 EDT 2009
Have you created an OSGeo login? Visit
http://www.osgeo.org/osgeo_userid. Once
you have that you should have rights to create tickets in the MapServer
trac instance.
Steve
>>> On 8/12/2009 at 1:38 AM, in message
<2349CC72A0B01C4FAA4FFAE6C735E1DDE291E7 at enerasrv01.Enera.local>, "Lars
Westerlind" <lars.westerlind at enera.se> wrote:
> Hello Jeff,
> Thanks for clarifications.
> I don't have TICKET_CREATE privilege it says.
> Cheers,
> Lars
> -----Ursprungligt meddelande-----
> Från: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] För Jeff McKenna
> Skickat: 11 August 2009 20:34
> Till: mapserver-users at lists.osgeo.org
> Ämne: Re: [mapserver-users] Newbie feedback
> Hello Lars,
> My comments are inline below:
> Lars Westerlind wrote:
>> Hello all,
>> we newly installed Mapserver as ms4w installation on windows; and we
are
>> very satisfied.
> great!
>> We got up and running very fast, even though we are not fluent in
the
>> techniques
>> used (in Partiucar, Apache webserver). However, I want to share a
few
>> small points that caused
>> unnecessary problems.
>> 1. A suggestion where in the directory structure to put the mapfiles
>> would be appreciated. If there are
>> different meanings, give two or three scenarios. Also include the
looks
>> of the URL reference to the mapfile.
> You should download the MS4W addon packed named "PHP/MapScript Sample
> Application" for an example directory structure. Here is my advice:
> - place the application in /ms4w/apps
> - /apps/yourapp/ should contain:
> /data (your data files)
> /docs (any relevant docs)
> /etc (font and symbol files)
> /htdocs (application files - often html, js, or php*)
> /maps (your mapfiles)
>> 2. Why not enclose a small working example with one simplest
possible
>> mapfile and one shapefile set? And
>> perhaps another more advanced mapfile with some common techniques
exposed?
> MS4W tries to do that, by providing you working examples that you can
> play around with.
>> 3. Font handling caused me much problems. As it is a windows
>> installation, it could be at least a insall note / readme
describing
>> where to search for the .ttf files. The Mapserver documentation
doesn't
>> say anything about Windows, and in Windows you need not be very
>> aware of where to find the font files, so it took some time to find
out.
>> It appears that the documentation is not very clear either;
>> I hade to create a fontset file and refer to it to get it work; the
>> documentation hints that font references could be written in the
fontset
>> clause, but I didn't manage.
> The best way to provide feedback on documentation (and make sure it
is
> recorded) is to file a ticket in the MapServer tracker
> (http://trac.osgeo.org/mapserver/), using the "MapServer
Documentation"
> component. It would be great help if your ticket could contain
> suggested text that should be added to the page you are referring to.
> Thanks!
>> 4. The default font handling (bitmap) was confusing as it appears to
be
>> ascii based, where the
>> true type font appears to be Unicode/UTF-8 based. When doing the
>> correct 'encoding', the output was silly until I managed to handel
the
>> true type fonts correctly.
> Maybe to be included in your ticket's text?
>> 5. I would suggest more examples in the documentation, especially
around
>> mapfile editing. In examles you
>> would also get punctuation issues and such
> Please do provide any examples that you think are relevant. You can
> also post examples and anything that you feel is helpful to others on
> the MapServer Wiki (see lower section of
> http://trac.osgeo.org/mapserver/)...it's an easy way to add to the
> documentation and help others quickly!
>> I think that was my most important points I think.
> Thanks for the feedback, keep it coming! :)
> -jeff
