[mapserver-users] Displaying Huge Data on Mapserver
Simon Haddon
simon at sibern.com.au
Wed Aug 19 16:57:50 EDT 2009
I have had a postgresql / postgis database with over 120 million rows of
point data in a single table and I have been amazed about how well
postgresql performs. As long as you get your indexes and queries right
then I would recommend that option for point data.
Cheers,
Simon
Frank Warmerdam wrote:
> Rishikant Lal wrote:
>> Dear Friends,
>> I need some help. I have a Point Feature Layer that I want to display
>> on Map Server. The layer has Nearly Ten Million Point Features.
> Rishikant,
> This is not a terribly large database though it is certainly large enough
> that care must be taken in how it is accessed.
>> What kind of Data Base should I use?
>> Will Post GIS support this kind of Data?
>> What are the steps I should use to speed up the Map Display Process?
> You should be able to achieve good performance with tile indexed
> shapefiles
> with indexes on the individual shapefiles and the tileindex. Some
> experimentation might be required to find an optimal breakdown. You
> could
> *try* it in one big shapefile with a spatial index but I have some doubts
> about whether this would give ideal performance.
> This dataset could also be well handled in PostGIS with a spatial index
> on the geometry column of course.
> A lot depends on what you want to do with this dataset of course. I'm
> assuming
> you want to render maps of very local regions with only a few
> thousands of
> points. Rendering points as symbols or labels can be expensive so we
> wary
> of trying to render too many on a map.
> Best regards,
