[mapserver-users] MapServer Oracle performance
Frank Warmerdam
warmerdam at pobox.com
Fri Aug 28 10:41:08 EDT 2009
Ivan wrote:
> Debugging those two process I noticed some important difference. shp2img
> calls GDALDatasetRasterIO and will ultimately calls the driver IRasterIO
> but without calling GetOverview first, so when it goes to the driver
> IReadBlock the level is 0. gdal_translate calls GetOverview and get the
> appropriated level but it does not touch the driver IRasterIO, it goes
> directly to the IReadBlock with the correct level. It Seams like QGIS
> does the same.
Ivan,
Yikes! On review I have reason to believe the GDALDataset::RasterIO()
method is not using overviews! I will investigate on this side as well.
I only very recently reworked the MapServer IO code to use
GDALDataset::RasterIO() instead of calls to GDALRasterBand::RasterIO()
so this isn't a problem that would have showed up in MapServer in the past.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
