[mapserver-users] WMS Client and SLD
Tony Baylis
tony.baylis at resexmap.com.au
Tue Dec 1 06:03:18 EST 2009
All,
This is the first time I have tried styling external WMS data using SLD
and cannot get the returned data/image in the desired style. Below is
the simplified mapfile and SLD file. If anyone has any pointers I'd be
more than grateful. Please note that the link to the SLD file does work
with the following return: 56
APPLICATION STATUS #ff0000 GRANTED STATUS #ffffbe
Tony
Mapfile:
# Start of map file
MAP
NAME qld_tenement
STATUS ON
SIZE 800 500
EXTENT 140 -23.25 150 -17
UNITS DD
SHAPEPATH "/var/www/remwms/htdocs/data"
IMAGECOLOR 192 213 255
SYMBOLSET "/var/www/remwms/htdocs/includes/symbols.sym"
FONTSET "/usr/share/fonts/truetype/font.list"
DEBUG 2
CONFIG "MS_ERRORFILE" "/var/www/ms_tmp/ms_error.txt"
#IMAGETYPE PNG
OUTPUTFORMAT
NAME "AGGA"
MIMETYPE "image/png"
DRIVER "AGG/PNG"
EXTENSION "png"
IMAGEMODE RGBA
TRANSPARENT ON
END
# Start of web interface definition
WEB
IMAGEPATH "/var/www/ms_tmp/"
IMAGEURL "http://mapserver1/ms_tmp/"
END
# Assign Projection
PROJECTION
"init=epsg:4283"
END
LAYER
NAME "EPM"
TYPE RASTER
STATUS ON
CONNECTIONTYPE WMS
CONNECTION
'http://atlas.information.qld.gov.au/ArcGIS/services/IRTM/MapServer/WMSServer?'
METADATA
"wms_srs" "EPSG:4326"
"wms_name" "56"
"wms_server_version" "1.1.1"
"wms_format" "image/png"
"wms_title" "EPM"
"wms_include_items" "all"
"wms_sld_url" "http://mapserver1/remwms/includes/sld/publicsld.xml"
"wms_legend_graphic" "0"
"wms_feature_info_mime_type" "text/plain"
END
END
END
SLD File:
<StyledLayerDescriptor version="1.0.0"
xmlns="http://www.opengis.net/sld"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/sld
http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd">
<NamedLayer>
<Name>56</Name>
<UserStyle>
<FeatureTypeStyle>
<Rule>
<Name>APPLICATION</Name>
<ogc:Filter><ogc:PropertyIsEqualTo><ogc:PropertyName>STATUS</ogc:PropertyName></ogc:PropertyIsEqualTo></ogc:Filter>
<PolygonSymbolizer>
<Fill>
<CssParameter name="fill">#ff0000</CssParameter>
</Fill>
</PolygonSymbolizer>
</Rule>
<Rule>
<Name>GRANTED</Name>
<PolygonSymbolizer>
<Fill>
<CssParameter name="fill">#ffffbe</CssParameter>
</Fill>
</Rule>
</FeatureTypeStyle>
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
Tony Baylis
Spatial Information Specialist
Resource and Exploration Mapping
Suite 8, 290 Boundary St
Spring Hill QLD 4000
Ph 3832 1600
Fax 3832 1603
Mob 0419 759 131
Email tony.baylis at resexmap.com.au
www resexmap.com.au
