[mapserver-users] Layer based on a view renders faster than if based on a table
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Fri Dec 4 12:35:18 PST 2009
I have a layer that renders faster when DATA is defined on a view than on
a table with a clustered index.
Here is the layer definition
  CONNECTIONTYPE postgis
  CONNECTION "host=xxxx dbname=xx user=xx password=xx port=5432"
  DATA "geom900913 FROM prevalence using unique id using srid=900913"
  PROCESSING "CLOSE_CONNECTION=DEFER"
  PROJECTION
    "init=epsg:900913"
  END
My MAP projection is also 900913
If prevalence is a
Postgis View: 0.469s (2.6 seconds in OpenLayers)
Postgis table: 0.781s (3.6 seconds in OpenLayers)
Postgis table+index+cluster: 0.782s ( 3.4 seconds  in OpenLayers)
I thought that a layer definition based on a table would be much faster
than on a view.
What should be the expected behavior please?
Please tell me is this should be asked to postgis forum.
thanks
Steve
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091204/358026db/attachment.htm>
More information about the MapServer-users mailing list
