[mapserver-users] Expression Syntax
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Fri Dec 11 09:55:18 EST 2009
Try:
FILTER (‘[USE1_DESC]’ =~ /.*%idOwnerQueryDESC%.*/i AND ‘[BLOCK]’=’%idOwnerQueryBLOCK%’)
I've not tried case insensitive regex in a logical expression though. You might have to remove the i...
Steve
________________________________________
From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jay Kapalczynski [jkapalczynski at ci.maple-grove.mn.us]
Sent: Friday, December 11, 2009 8:37 AM
To: Fawcett, David (MPCA); 'Emiliano Castañeda'
Cc: mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] Expression Syntax
Thanks for all your help yesterday….very appreciated…seems I always get botched up with the syntax….
Ugggg…I have tried 20 different ways and I just seem to be missing something..
I guess the question is, Can I use a wild card search in a logical expression?
This works (WILD CARD )
FILTER /.*%idOwnerQueryDESC%.*/i
This works (NO WILD CARD)
FILTER (‘[USE1_DESC]’=’%idOwnerQueryDESC%’ AND ‘[BLOCK]’=’%idOwnerQueryBLOCK%’)
This DOSENT work (Cant get the wild card into this)
FILTER (‘[USE1_DESC]’=’ /.*%idOwnerQueryDESC%.*/i’ AND ‘[BLOCK]’=’%idOwnerQueryBLOCK%’)
Any thoughts?
Thanks
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jay Kapalczynski
Sent: Thursday, December 10, 2009 3:57 PM
To: 'Fawcett, David (MPCA)'; 'Emiliano Castañeda'
Thanks all for your thoughts….
Got it…I had to add ‘ ‘ around the textbox id as well when referencing the textbox id names
Notice( ’%idOwnerQueryDESC%’ and ’%idOwnerQueryBLOCK%’ )
Dan thanks for your thoughts…I am going to be moving to 2.x soon….but have to have the time to lean this all over again…moving to open layers that is….
One step at a time…I have a ton programmed into 1.6 that’s going to take me some time to convert…
Thanks again all….very appreciated
From: Fawcett, David (MPCA) [mailto:David.Fawcett at state.mn.us]
Sent: Thursday, December 10, 2009 3:26 PM
To: Jay Kapalczynski; 'Emiliano Castañeda'
At a minimum, I think that you will need to add quotes around the query columns. (just use single quotes, not the fancy Microsofty ones below…)
FILTER (‘[USE1_DESC]’=%idOwnerQueryDESC% AND ‘[BLOCK]’=%idOwnerQueryBLOCK%)
Try setting a filter with static values from your data to get the filter format working before you add the complexity of passing the values in with variables.
FILTER (‘[USE1_DESC]’=’myUse’ AND ‘[BLOCK]’=’myBlock’)
David.
Sent: Thursday, December 10, 2009 3:21 PM
To: 'Emiliano Castañeda'
Emiliano thanks for the response….yea I looked at the documentation and it was a bit fuzzy to me…
If I do them individually it works:
#FILTERITEM 'USE1_DESC'
#FILTER /.*%idOwnerQueryDESC%.*/i
#FILTERITEM 'BLOCK'
#FILTER /.*%idOwnerQueryBLOCK%.*/i
FILTER ([USE1_DESC]=%idOwnerQueryDESC% AND [BLOCK]=%idOwnerQueryBLOCK%)
ERROR: msEvalExpression: Expression parser error. Failed to parse expression: =Residential AND =006
FILTER (USE1_DESC=%idOwnerQueryDESC% AND BLOCK=%idOwnerQueryBLOCK%)
I seemed to get a bunch of returns that were incorrect...seems like it grabbed all of them.
Thoughts?
From: Emiliano Castañeda [mailto:emilianocastaneda at suremptec.com.ar]
Sent: Thursday, December 10, 2009 2:13 PM
Subject: Re: [mapserver-users] Expression Syntax
Jay,
you must use FILTERITEM only for simple FILTER expressions (string comparison only)
for example:
FILTER "2005" ->fieldvalue
FILTERITEM "year" ->fieldname
For Logical FILTER expressions you do not define FILTERITEM. In this case you must place the FILTER between parentheses, and fieldnames between brackets
for example:
FILTER ([field1]<4000 AND "[field2]"=="Museum") -->observe quotes on both sides on text fields
See http://mapserver.org/mapfile/expressions.html#expressions for detail on how to build logical expressions
Regards,
Emiliano
2009/12/10 Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us<mailto:jkapalczynski at ci.maple-grove.mn.us>>
I looked on map server website in the documentation and cant get the synstax correct
I have two textboxes idOwner and idOwner2
I am a bit confused on the FILTERITEM because I am trying to write the expression to include two fields.
USE1_DESC and BLOCK are the two fields that form the query
LAYER # Parcels Owner Layer
NAME 'Parcels'
DATA 'parcels/parcels.shp'
STATUS DEFAULT
TYPE POLYGON
METADATA
qstring_validation_pattern '.'
END
TEMPLATE 'parcels/itemquery_parcels_Owner.html'
FILTER (* WHERE USE1_DESC = '%idOwner%' and BLOCK = '%idOwner2%')
END
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Ing. Emiliano Castañeda
SUR Emprendimientos Tecnológicos
Ing. Huergo 1189 (C1007AOL)
Ciudad de Buenos Aires, Argentina
Tel. +54 (11) 5811-4552 ext. 107
emilianocastaneda at suremptec.com.ar<mailto:emilianocastaneda at suremptec.com.ar>
www.suremptec.com<http://www.suremptec.com>
