[mapserver-users] make error - version 5.6.0-rc1 - /usr/bin/ld: cannot find -lxslt
Ted Spradley
tspradley at snoogems.com
Fri Dec 11 08:08:59 PST 2009
Stephen Woodbridge wrote:
> http://www.google.com/#hl=en&source=hp&q=fedora+7+libpam
> -Steve
Not having libpam doesn't appear to be the issue. It just can't find it.
/usr/bin/ld: cannot find -lpam
# locate libpam
/lib/libpam.so.0
/lib/libpam.so.0.81.6
/lib/libpam_misc.so.0
/lib/libpam_misc.so.0.81.2
/lib/libpamc.so.0
/lib/libpamc.so.0.81.0
/root/psa/PSA_8.4.0/dist-rpm-FedoraCore-7-i386/base/psa-libpam-plesk-8.4.0-fc7.build84080425.19.i586.rpm
/root/psa/PSA_9.2.3/dist-rpm-FedoraCore-7-i386/base/psa-libpam-plesk-9.2.3-fc7.build92091015.22.i586.rpm
/swsoft/PSA_8.3.0/dist-rpm-FedoraCore-7-i386/base/psa-libpam-plesk-8.3.0-fc7.build83071218.19.i586.rpm
Is there any way to feed make the path for this library?
Thanks, Ted S.
View this message in context: http://n2.nabble.com/make-error-version-5-6-0-rc1-usr-bin-ld-cannot-find-lxslt-tp4148052p4152101.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
More information about the MapServer-users
