[mapserver-users] Help with NQuery error (CGI)
Paul james
pauljame at gmail.com
Tue Dec 15 12:26:13 EST 2009
Hi Steve...
Any update on MSSQL2008 driver to solve that bug?
Thanks
On Fri, Oct 30, 2009 at 2:48 PM, Steve Lime <Steve.Lime at dnr.state.mn.us>wrote:
> Probably. Does a point query work? I reassigned the ticket to the keeper
> of the SQLServer
> driver in hopes that it gets attention.
> Curiously, have you tried 5.6 at all with SQLServer?
> Steve
> >>> On 10/30/2009 at 12:22 PM, in message
> <33fad6880910301022s40c76f88ha011362964e21808 at mail.gmail.com>, Paul
> james
> <pauljame at gmail.com> wrote:
> > I think so...
> > Is it related with that ticket?
> > http://trac.osgeo.org/mapserver/ticket/3058
> > Paul
> > On Fri, Oct 30, 2009 at 1:53 PM, Steve Lime
> >> Odd. Unfortunately I can't debug anything related to MSSQL2008,
> perhaps
> >> the driver isn't
> >> supporting functions necessary to complete a query?
> >> Steve
> >> >>> On 10/30/2009 at 6:33 AM, in message
> >> <33fad6880910300433i342c619am99935a607896643f at mail.gmail.com>, Paul
> >> james
> >> > Hey Steve...
> >> > Yes I had...
> >> > QUERYMAP
> >> > COLOR 255 0 0
> >> > SIZE -1 -1
> >> > STATUS ON
> >> > STYLE hilite
> >> > END
> >> > With Status OFF I got that :
> >> > Content-type: text/html
> >> > Using MSSQL2008
> >> > Paul
> >> > On Thu, Oct 29, 2009 at 6:13 PM, Steve Lime
> >> >> Do you have a querymap object configured with status on? I would
> >> guess
> >> >> so in order to see that
> >> >> error. What happens if you set STATUS OFF in the querymap?
> >> >> >>> On 10/29/2009 at 7:57 AM, in message
> >> >> <33fad6880910290557m71ee3fdatd470590e3256f175 at mail.gmail.com>,
> Paul
> >> >> james
> >> >> > Hello guys...
> >> >> > Ím got this error when trying to execute a Nquery :
> http://localhost/cgi-bin-54/mapserv.exe?map=Map.map&mode=nquery&LAYERS=TEST&mape
> >> > x
> t=-58.358076171875+-11.42570625+-57.193525390625+-10.37101875&imgext=-58.35807
> >> > 61718
> 75+-11.42570625+-57.193525390625+-10.37101875&map_size=1221+762&imgxy=1221+762&i
> >> > mgb
> >> >> > ox=0+0+1221+762
> >> >> > msDrawMap(): Image handling error. Failed to draw layer named
> >> >> 'TEST'.
> >> >> > But, If I execute the same url with "mode=map", the image is
> >> >> generated
> >> >> > fine... What this error means?
> >> >> > TEST Layer
> >> >> > LAYER
> >> >> > NAME TEST
> >> >> > GROUP "TE"
> >> >> > TYPE polygon
> >> >> > STATUS ON
> >> >> > CONNECTIONTYPE PLUGIN
> >> >> > PLUGIN "msplugin_mssql2008.dll"
> >> >> > CONNECTION "server=X;Integrated
> >> >> Security=false;database=X;uid=X;pwd=X"
> >> >> > DATA "the_geom from viw USING UNIQUE oid USING SRID=0"
> >> >> > CLASS
> >> >> > TEMPLATE "template.html"
> >> >> > NAME "X"
> >> >> > STYLE
> >> >> > OUTLINECOLOR 150 150 150
> >> >> > WIDTH 1
> >> >> > END
> >> >> > END
> >> >> > END
> >> >> > Thanks
> >> >> > Paul
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091215/a66d39b5/attachment.html
