[mapserver-users] msGetEncodedString(): General error message.
Not implemeted since Iconv is not enabled.
woodhead31
pearce_wang at hotmail.com
Sun Dec 27 04:43:39 EST 2009
Great, solved!
Thanks a lot!
Daniel Morissette wrote:
> I'd suggest you try adding --with-libiconv=/usr/local to your configure
> options to force configure to enable it, and then 'make clean;make'
> Daniel
> woodhead31 wrote:
>> Hi,
>> I am moving from windows to freebsd 7.2, but got some error:
>> msGetEncodedString(): General error message. Not implemeted since Iconv
>> is
>> not enabled.
>> OS: freebsd 7.2
>> Mapserver: installed from ports
>> The map file works perfect in a windows system, and I just move the
>> whole
>> application to freebsd, including mapfile , symbols, fonts etc. I think
>> it's the iconv problem.
>>>From the install manual:
>> http://mapserver.org/installation/unix.html#libgd
>> I belive it's the GD and ICONV problem, so try to execute
>> gdlib-config --libs
>> and got:
>> -lXpm -lX11 -ljpeg -lfontconfig -lfreetype -lz -lm
>> /usr/local/lib/libiconv.so -Wl,-rpath -Wl,/usr/local/lib
>> I have iconv installed:
>> pkg_info |grep iconv
>> libiconv-1.13.1 A character set conversion library
>> I think I installed iconv(as the pkg_info shows), and make gd with
>> iconv(as
>> the gdlib-config shows).
>> what should I do then?
>> thanks!
> Daniel Morissette
> http://www.mapgears.com/
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/msGetEncodedString-General-error-message-Not-implemeted-since-Iconv-is-not-enabled-tp4213774p4220097.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
