[mapserver-users] mapserver and pmapper
VladimirC
vladimir at gessolutions.com
Sun Feb 1 17:04:19 EST 2009
Same problem running MapServer 5.0.3 and Pmaper 3.2 installed as Debian
binaries. Were you able to resolve?
Victor Sterpu wrote:
> In compiled mapserver 5.2.0 and everythig works fine.
> But when I tryed to use pmapper I receive this MapServer error:
> Warning: [MapServer Error]: msEvalRegex(): String (/var/www/pmap/config)
> failed expression test. in /var/www/pmap/incphp/globals.php on line 60
> Warning: Failed to open map file /var/www/pmap/config in
> Fatal error: Call to a member function getAllGroupNames() on a
> non-object in /var/www/pmap/incphp/init/initmap.php on line 129
> Pmapper is version 3.2.0.
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/mapserver-and-pmapper-tp1972469p2255392.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
