[mapserver-users] application\vnd.ogc.se_inimage format
Piebe de Vries
piebe.de.vries at geodan.nl
Tue Feb 3 05:34:30 EST 2009
imagetype is set to png
the only defined output type is png
Yewondwossen Assefa wrote:
> Hi There,
> Is the IMAGETYPE parameter set in your map file? If not you might
> want to try it by adding something like this in your map file:
> IMAGETYPE png (or any other valid formats that you want).
> Best Regards
> Piebe de Vries wrote:
>> hi,
>> I configured a layer to return png only. When my application does a
>> getMap request (using format=image/png) a png picture is returned.
>> Everything fine so far. However if an error occurs the same request
>> (using exceptions=application\vnd.ogc.se_inimage) returns a gif
>> picture. And my application is not very happy with that...(also the
>> wms standards specifies that the image returned should be the one
>> asked in the format parameter)
>> I am using mapserver 5.2.1 Can anybody confirm this behavior?
>> Thanks,
>> Piebe
Piebe de Vries piebe.de.vries at geodan.nl
Geodan IT b.v. Tel: +31 (0)73 - 6925 151
President Kennedylaan 1 Fax: +31 (0)73 - 5711 333
1079 MB Amsterdam (NL) http://www.geodan.nl
