[mapserver-users] Different SIZEUNITS for line width and label
fontsize
thomas bonfort
thomas.bonfort at gmail.com
Tue Feb 3 06:49:02 EST 2009
Hi again,
using:
size 8
minsize 8
maxsize 8
is *exactly* the same as using only size 8 with pixel sizeunits
i.e. this effectively prevents the labels scaling at all
regards,
thomas
On Tue, Feb 3, 2009 at 12:41, Vladimir Cvejanovic
<vladimir at gessolutions.com> wrote:
> Hi Thomas,
> Thanks for your reply. I have already plaid around with MINSIZE and MAXSIZE.
> They are a good way to avoid the labels being displayed when they are too
> small to read. Also coupled with MINSCALE and MAXSCALE class definitions I
> was able to set up three classes for large, medium and small text depending
> on the scale used.
> This isn't a bad solution at all but I wanted to see if there is away to
> prevent the labels scaling at all within the same layer definition as the
> scalable (real-world sized) lines.
> Thanks,
> Vladimir
> thomas bonfort wrote:
>> hi,
>> you can use minsize and maxsize in your label: these are always pixels:
>> size 8
>> minszie 8
>> maxsize 8
>> regards,
>> thomas
>> On Tue, Feb 3, 2009 at 12:17, Vladimir Cvejanovic
>>> Hi All,
>>> In the Mapfile, Is it possible to have different SIZEUNTIS for line width
>>> and label font in the same layer? The example is below.
>>> I have managed to solve this by defining two layers one which only
>>> displays
>>> the line and one which only displays the labels however this seems like a
>>> hack and very inefficient from a processing / querying point of view.
>>> The context is a line layer containing road lines which have a width in
>>> meters but labels in pixels. This would make things scale nicely Can this
>>> be
>>> done? Does anyone have a better approach?
>>> Thanks,
>>> Vladimir
>>> LAYER
>>> NAME 'highway'
>>> TYPE LINE
>>> DATA 'highway.shp'
>>> STATUS DEFAULT
>>> TRANSPARENCY 30
>>> LABELITEM "NAME"
>>> SIZEUNITS meters
>>> CLASS
>>> NAME 'highway'
>>> STYLE
>>> WIDTH 5 #WANT THESE TO BE METERS
>>> COLOR 55 55 55
>>> END
>>> LABEL
>>> TYPE TRUETYPE
>>> FONT FreeSans
>>> SIZE 08 # WANT THESE TO BE PIXELS
>>> COLOR 0 0 0
>>> OUTLINECOLOR 255 255 255
>>> ANTIALIAS TRUE
>>> ANGLE AUTO
>>> MINFEATURESIZE AUTO
>>> FORCE true
>>> END
>>> END
>>> END
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
