[mapserver-users] Expressions
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Feb 4 11:55:05 EST 2009
Jay Kapalczynski wrote:
> I am trying to do expressions based on a shapefile…I had this working in
> a prior version but now it wont work…
> The fields GEO_SIMPLE and dateValues exist in the shapefile.
> I have the date values in “dateValues” as TEXT, 8 characters.
> The Star symbols come up but the application freezes up and wont draw
> the rest of the layers…so I have something wrong…
> Does the date format have to be changed?
> Does the field have to be a date field?
> Will the below format work? ("%2M%2D%2Y)
> But in the field it looks like this *11509*
> If I remove the param types and the expression stuff it draws the layer
> fine…so it has to be with the dates.
> THANKS IN ADVANCE FOR ANY HELP
> I get this error:
> Strfdate is not defined
> mapParams[i].SetAttribute(‘value’,strfdate(new
> Date(d.getTime()+offset),formats…………
> *DEMO.XML*
> <map title="Burglaries" default="true" reference="false"
> popups="true" data="true">
> <param type="today" offset="-7" name="LASTWEEK"
> format="%2M%2D%2Y"/>
> <param type="today" offset="-14" name="LASTTWOWEEKS"
> <param type="today" offset="-30" name="LASTTHIRTY"
> <param type="today" offset="-90" name="LASTNINTY"
> <file>/ms4w/apps/GeoMOOSE/Maple_Grove_GeoMoose/Burglaries/Burglaries_8bit.map</file>
> </map>
> *BURGLARIES.map*
> CLASS
> NAME 'Last Week'
> EXPRESSION ('[GEO_SIMPLE]' =
> 'BURGLARY' AND '[dateValues]' > '%LASTWEEK%')
> COLOR 197 0 255
> SYMBOL "star"
> SIZE 12
> END
> CLASS
> NAME 'Last Two Weeks'
> 'BURGLARY' AND '[dateValues]' > '%LASTTWOWEEKS%')
> COLOR 255 0 0
> SYMBOL "star"
> SIZE 12
> END
> CLASS
> NAME 'Last Thirty Days'
> 'BURGLARY' AND '[dateValues]' > '%LASTTHIRTY%')
> COLOR 0 255 0
> SYMBOL "star"
> SIZE 12
> END
> CLASS
> NAME 'Last Ninety Days'
> 'BURGLARY' AND '[dateValues]' > '%LASTNINTY%')
> COLOR 0 0 255
> SYMBOL "star"
> SIZE 12
> END
The first thing you might try is a shp2img command
(http://mapserver.org/utilities/shp2img.html) with the -map_debug switch
(see example on that page) and then report the errors listed in that
command result to this mapserver-users email list.
-jeff
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
