[mapserver-users] Any way to measure between two picked points?
Alexandre Dube
adube at mapgears.com
Thu Feb 5 08:34:44 EST 2009
I don't have a direct solution to your problem. I rather have
propositions. You could use a client-side application like Chameleon (1)
or Openlayers (2). Both have that kind of tool already, see one in
Openlayers (3). You could also check their code to custom your own in
your html template.
Hope this helps,
Alexandre
(1) http://openlayers.org/
(2) http://chameleon.maptools.org/
(3)
http://dev.openlayers.org/sandbox/jvanulden/openlayers/examples/extended-layerswitcher.html
boesiii wrote:
> I am using mapserver with an html template. Is there anyway to add a tool
> that would enable a user to pick two points on a map and have it tell the
> distance between the two points?
Alexandre Dubé
Mapgears
www.mapgears.com
