[mapserver-users] Re: symbol problem
Valeria Muñoz
valemunoz at gmail.com
Thu Feb 5 12:30:28 EST 2009
HI!
I found the problem :
OUTPUTFORMAT
NAME png
DRIVER "AGG/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB #RGBA transparente
EXTENSION "png"
FORMATOPTION "TRANSPARENT=OFF"
FORMATOPTION "INTERLACE=ON"
END
do you know why does not work with this configuration?
RG
2009/2/5 Valeria Muñoz <valemunoz at gmail.com>
> Hi
> I have problems with displaying symbols,I can not give the correct
> orientation-... attached image of my problem
> LAYER
> NAME 'calle'
> MAXSCALE 5000
> TYPE LINE
> DATA 'calle.shp'
> METADATA
> 'wms_title' 'calle'
> END
> STATUS DEFAULT
> TRANSPARENCY 100
> PROJECTION
> 'proj=longlat'
> 'ellps=WGS84'
> 'datum=WGS84'
> 'no_defs'
> END
> #LABELITEM 'ONEWAY'
> CLASS
> EXPRESSION ('[HWYLEVEL]' = '4' and '[ONEWAY]'='0')
> #TEXT (<->)
> #NAME 'calle'
> STYLE
> SYMBOL 'flecha_ambos'
> SIZE 13
> ANGLE 0
> #OUTLINECOLOR 161 189 196
> #COLOR 0 0 0
> END
> LABEL
> TYPE truetype
> FONT 'georgia'
> SIZE 6
> ANTIALIAS TRUE
> COLOR 156 0 0
> ANGLE FOLLOW
> #MINDISTANCE -1
> #MINFEATURESIZE -1
> OFFSET 5 0
> FORCE FALSE
> POSITION CC
> BUFFER 10
> PARTIALS FALSE
> END
> END
> END
> SYMBOL
> NAME "flecha_ambos"
> TYPE PIXMAP
> IMAGE
> "C:/ms4w/Apache/htdocs/mapFile/mapas/etc/icons/arrow_left_right.png"
> GAP -50
> END
> RG
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090205/db4108e7/attachment.html
