[mapserver-users] newbie mapserver question
Derek Gilby
dgilby at chebucto.ns.ca
Mon Feb 9 07:51:21 EST 2009
Hi How are things?
I know it is possible, although this website is for SVG it will give you an idea
of what can be done, look at http://www.carto.net/
Derek
new2ms4w wrote:
> Hello Everyone,
> I've very recently started working on a project to display some moving
> objects on a road network in the map.
> I would like to (dynamically) display moving objects on a road map.
> I got the mapserver up and running on my machine and have read some
> documentation from the mapserver website.
> What I intend to do is add some points to a layer on top of the roads layer
> and keep changing their position so that they appear to be constant moving
> on the roads.
> Has anyone done this kind of stuff before. I would like to know if I'm going
> in the right direction...
> Also, can someone point to the Perl-Mapscript binaries for mapserver. I'm
> currently using MS4W software which doesn't include them.
> Thank you for your time.
> ~PN
> No virus found in this incoming message.
> Checked by AVG - www.avg.com
> Version: 8.0.233 / Virus Database: 270.10.19/1940 - Release Date: 02/07/09 13:39:00
Derek Gilby
30 Samuel Danial Drive
Eastern Passage, NS
B3G 1P7
902 404-2741
www.DerekGilby.org
** Propensity to think through/beyond the problem and provide possible options
for a solution. **
