[mapserver-users] symbol problem
Valeria Muñoz
valemunoz at gmail.com
Mon Feb 9 12:50:45 EST 2009
David
I make the changes and does not works
RG
2009/2/9 Fawcett, David <David.Fawcett at state.mn.us>
> My assumption was that the problem was likely only with AGG rendering.
> Please try the suggestions that I made in my last message and let me know
> how they work, particularly setting the GAP value to a positive number.
> David.
> -----Original Message-----
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Valeria Muñoz
> *Sent:* Monday, February 09, 2009 11:26 AM
> *To:* Fawcett, David
> *Cc:* mapserver-users
> *Subject:* Re: [mapserver-users] symbol problem
> hi david..
> If i change the "OUTPUTFORMAT"configuration to:
> OUTPUTFORMAT
> NAME gif
> DRIVER 'GD/GIF'
> MIMETYPE 'image/gif'
> #IMAGEMODE PC256
> EXTENSION 'gif'
> END
> works... i thinks is a problem of AGG
> RG
>> Valeria,
>> It would be useful if you provided more information. What version of
>> MapServer are you using? What were you expecting to see?
>> Because you are setting your symbol angle to 0, I am guessing that you
>> want all of the arrows to point to the top of the map.
>> I am aware of a bug in AGG rendering where TrueType symbols are not
>> corrrectly rotated (fixed in trunk), but I haven't seen a problem with
>> pixmap symbols.
>> In the symbol block of your layer, try commenting out the SIZE property.
>> I think that you really just want your pixmap symbol to be displayed in its
>> native size.
>> Also, in your symbol definition at the end of your map file, try changing
>> the value of GAP from -50 to 50.
>> David.
>> *Sent:* Monday, February 09, 2009 6:39 AM
>> *To:* mapserver-users
>> *Subject:* [mapserver-users] symbol problem
>> Hi
>> I have problems with displaying symbols,I can not give the correct
>> orientation-... do you know why does not work with this configuration?
>> attached image of my problem
>> OUTPUTFORMAT
>> *NAME png
>> DRIVER "AGG/PNG"*
>> MIMETYPE "image/png"
>> IMAGEMODE RGB #RGBA transparente
>> EXTENSION "png"
>> FORMATOPTION "TRANSPARENT=OFF"
>> FORMATOPTION "INTERLACE=ON"
>> END
>> LAYER
>> NAME 'calle'
>> MAXSCALE 5000
>> TYPE LINE
>> DATA 'calle.shp'
>> METADATA
>> 'wms_title' 'calle'
>> END
>> STATUS DEFAULT
>> TRANSPARENCY 100
>> PROJECTION
>> 'proj=longlat'
>> 'ellps=WGS84'
>> 'datum=WGS84'
>> 'no_defs'
>> END
>> #LABELITEM 'ONEWAY'
>> CLASS
>> EXPRESSION ('[HWYLEVEL]' = '4' and '[ONEWAY]'='0')
>> #TEXT (<->)
>> #NAME 'calle'
>> STYLE
>> SYMBOL 'flecha_ambos'
>> SIZE 13
>> ANGLE 0
>> #OUTLINECOLOR 161 189 196
>> #COLOR 0 0 0
>> END
>> LABEL
>> TYPE truetype
>> FONT 'georgia'
>> SIZE 6
>> ANTIALIAS TRUE
>> COLOR 156 0 0
>> ANGLE FOLLOW
>> #MINDISTANCE -1
>> #MINFEATURESIZE -1
>> OFFSET 5 0
>> FORCE FALSE
>> POSITION CC
>> BUFFER 10
>> PARTIALS FALSE
>> END
>> END
>> END
>> SYMBOL
>> NAME "flecha_ambos"
>> TYPE PIXMAP
>> IMAGE
>> "C:/ms4w/Apache/htdocs/mapFile/mapas/etc/icons/arrow_left_right.png"
>> GAP -50
>> END
>> RG
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090209/92d79f9b/attachment-0001.html
