[mapserver-users] hide .map contents
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Feb 10 22:27:43 EST 2009
Greg Luker wrote:
> Hi Stephen,
> At 10:37 AM 11/02/2009, you wrote:
>> Just move you map file outside the apache root directory.
> Thanks for your reply. As far as I know, the .map file is already
> outside the apache root directory. Attached is the 'View/Source' output
> - I just noticed error messages in it - does this point to a problem? (I
> replaced sensitive info with ***)
yes, this is an error message, not your mapfile. Granted it does have
mapfile information in it and more specifically it is an error generated
by the GDAL libraries from within mapserver.
So, I am reposting this to the list, because there are probably people
there that are better able to respond to this issue, which is why it is
always good to do a Reply All so the message goes back to the list and
it helps other that might have the same problem searching the archives.
-Steve W
<html>
<HEAD>
<TITLE>CHAMP - Query Results - Public</TITLE>
<HR>
</HEAD>
<font size+1>
<b>Layer: pts</b>
</font><p>
<table cellpadding=3 cellspacing=3 border=1>
<tr bgcolor=#FFD0D0>
<th>Code</th>
<th>Name</th>
<th>Description</th>
<th>Comment</th>
<th>Gender Access</th>
<th>Aboriginal Land Council</th>
<th>Date Recorded</th>
</tr>
<br>
<!--msBuildPath(): Unable to access file. (/var/mapserver/champ/<OGRVRTDataSource>
<OGRVRTLayer name="pexact">
<SrcDataSource>MYSQL:***,user=***,password=***,host=127.0.0.1,port=3306,tables=feature;site;genderaccess;featdesc;lalc</SrcDataSource>
<SrcSQL>
SELECT
DISTINCTROW
s.site_id,
s.site_code,
fp.featurePerson_person_id,
fp.featurePerson_task_id,
fd.featdesc_description,
f.feature_recorded_date,
f.feature_comment,
f.feature_other,
f.feature_validation_date,
ga.genderaccess_description,
p.person_firstname,
p.person_surname,
p.person_status,
p.person_gender,
s.site_name,
s.site_easting_other,
s.site_northing_other,
t.task_id,
t.task_code,
l.lalc_id,
l.lalc_name
FROM
site s
INNER JOIN feature f ON s.site_id = f.feature_site_id
RIGHT OUTER JOIN featdesc fd ON f.feature_featdesc_id = fd.featdesc_id
LEFT OUTER JOIN genderaccess ga ON f.feature_genderaccess_id = ga.genderaccess_id
LEFT OUTER JOIN featurePerson fp ON f.feature_id = fp.featurePerson_feature_id
LEFT OUTER JOIN person p ON fp.featurePerson_person_id = p.person_id
LEFT OUTER JOIN task t ON fp.featurePerson_task_id = t.task_id
LEFT OUTER JOIN lalc l ON s.site_lalc_id = l.lalc_id
WHERE
(s.site_other = "E")
ORDER BY fd.featdesc_code, t.task_id, p.person_surname
</SrcSQL>
<GeometryType>wkbPoint</GeometryType>
<GeometryField encoding="PointFromColumns" x="site_easting_other" y="site_northing_other"/>
</OGRVRTLayer>
</OGRVRTDataSource>): path is too long;msBuildPath: Unable to access file. ;msBuildPath(): Unable to access file. (./data<OGRVRTDataSource>
<SrcSQL>
SELECT
DISTINCTROW
s.site_id,
s.site_code,
f.feature_comment,
f.feature_other,
p.person_firstname,
p.person_surname,
p.person_status,
p.person_gender,
s.site_name,
t.task_id,
t.task_code,
l.lalc_id,
l.lalc_name
FROM
site s
WHERE
</SrcSQL>
</OGRVRTLayer>
</OGRVRTDataSource>): path is too long;msBuildPath(): Unable to access file. (/var/mapserver/champ/<OGRVRTDataSource>
<SrcSQL>
SELECT
DISTINCTROW
s.site_id,
s.site_code,
f.feature_comment,
f.feature_other,
p.person_firstname,
p.person_surname,
p.person_status,
p.person_gender,
s.site_name,
t.task_id,
t.task_code,
l.lalc_id,
l.lalc_name
FROM
site s
WHERE
</SrcSQL>
</OGRVRTLayer>
<SrcSQL>
SELECT
DISTINCTROW
s.site_id,
s.site_code,
f.feature_comment,
f.feature_other,
p.person_firstname,
p.person_surname,
p.person_status,
p.person_gender,
s.site_name,
t.task_id,
t.task_code,
l.lalc_id,
l.lalc_name
FROM
site s
WHERE
</SrcSQL>
</OGRVRTLayer>
</OGRVRTDataSource>): path is too long;getString(): Symbol definition error. Parsing error near (DD):(line 633)-->
<!-- MapServer version 5.2.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS INPUT=TIFF INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
<tr bgcolor=#FFFFD0>
<td>BMP-05-0001</td>
<td>Mount Warning</td>
<td>Stone arrangement</td>
<td>The NPWS Aboriginal Cultural Heritage Study Mt Warning (Wollumbin) NP, 2001, records information from Elder, John Roberts, that twin stones of contrasting colours were once located on the mountains summit. See also BMP-05-0082.</td>
<td>Male only access</td>
<td>Tweed Byron</td>
<td>2005/02/14</td>
</tr>
</table>
<FORM><INPUT TYPE="button" VALUE="Back" onClick="history.go(-1);return true;"> </FORM>
</body>
</html>
