[mapserver-users] How can I do a SQL text comparison in a mapfile?
Bob Basques
Bob.Basques at ci.stpaul.mn.us
Thu Feb 12 14:56:00 EST 2009
This was just talked about this past week in another thread.
I don't believe there is a method for escaping the internal quotes in the SQL statement you show. Possible option(s) would be to add a numeric column to the DB table/view for filtering on. Or make a call that returns more using a different SQL filter and use EXPRESSIONs in the Layer CLASS to filter further for display. This doesn't seem like the economical way to do things things though.
There was some stuff done in recent versions of MapServer though in EXPRESSIONs that may be related.
bobb
>>> Travis Kirstine <traviskirstine at gmail.com> 02/12/09 1:45 PM >>>
The following line does not work and I think it has something to do
with the single quotes. When I use double quotes Postgres thinks I'm
referring to a column name. Is there a way to escape the single
quotes?
DATA "geom from (select id as oid, geom from some_table where
some_field = 'some_string') as myquery using SRID=-1"
The following line works because I'm doing a numeric comparison.
some_field_number = 99) as myquery using SRID=-1"
Travis K.
Toronto, Canada
"She knows there's no success like failure
And that failure's no success at all."
-Bob Dylan-
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
