[mapserver-users] GetFeatureInfo and HDF5
Espen.Messel at ffi.no
Mon Feb 16 01:55:38 EST 2009
Hi all..
I'm having problems with HDF5 raster files and GetFeatureInfo with
MapServer.
When trying to get some pixel data out, I always get the Empty template
from the WEB section.
Is it some special way to handle HDF5 files?
When I use gdal_translate and convert the file into GTiff and change the
DATA line in my mapfile everything works fine.
I probably get 100 HDF5 images an hour, so I hope to use them without
converting them into geotiffs.
Regards,
Espen Messel
MAPFILE:
LAYER
NAME "radar"
TYPE RASTER
DUMP TRUE
STATUS OFF
DATA 'HDF5:"/tmp/data/aeqd-1000.hdf"://image1/data'
# DATA test.tif
HEADER "/etc/templates/header.html"
FOOTER "/etc/templates/footer.html"
TEMPLATE "/etc/templates/radar.html"
TOLERANCE 10
TOLERANCEUNITS miles
OPACITY 90
PROJECTION
"init=epsg:4326"
END
INCLUDE "radar_metadata.map"
INCLUDE "radar_color.map"
END
Espen Messel
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090216/46aaec06/attachment.html
