[mapserver-users] SOS response XML validity
MassimoF
massimo.ferraguto at ssf.fi
Mon Feb 16 09:49:32 EST 2009
Hello,
I have created a mapfile to generate a SOS response containing data from a
database. I have understood that mapserver supports only "flat" reporting of
the database columns to the xml response.
My problem is that I wonder whether this kind of "flat" response is valid or
not. If I try to validate the response against the xml schema I get errors.
How can I solve this problem of xml validity against the schema?
Here are the errors:
*** Error start ***
Element <observedProperty> is not allowed under element <om:Observation>.
Reason: The following elements are expected at this location (see below)
<om:observedProperty>
<om:resultQuality>
Annotations of type 'om:ObservationType' (see below)
Base type for Observations.
Observation is an act ("event"), whose result is an estimate of the value of
a property of the feature of interest.
The observed property may be any property associated with the type of the
The following properties are inherited from AbstractFeatureType:
Error location: om:ObservationCollection / om:member / om:Observation /
observedProperty
Details
cvc-model-group: Element <observedProperty> unexpected by type
'om:ObservationType' of element <om:Observation>.
cvc-elt.5.2.1: The element <om:Observation> is not valid with
respect to the actual type definition 'om:ObservationType'.
*** Error end ***
after modifying observedProperty ==> om:observedProperty I get another
error:
*** Error start ***
Text 'temperature' is not allowed for element <om:observedProperty>. The
element declaration's content type is 'element-only'.
om:observedProperty
Details
cvc-complex-type.2.3: Text 'temperature' is not allowed for element
<om:observedProperty>. The element declaration's content type is
'element-only'.
cvc-elt.5.2.1: The element <om:observedProperty> is not valid with
respect to the actual type definition 'swe:PhenomenonPropertyType'.
*** Error end ***
Here is an example response that I get from my server:
<?xml version="1.0" encoding="ISO-8859-1"?>
<om:ObservationCollection xmlns:gml="http://www.opengis.net/gml"
xmlns:ows="http://www.opengis.net/ows/1.1"
xmlns:swe="http://www.opengis.net/swe/1.0.1"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:sos="http://www.opengis.net/sos/1.0"
xmlns:om="http://www.opengis.net/om/1.0" gml:id="htb_offering"
xsi:schemaLocation="http://www.opengis.net/om/1.0
http://schemas.opengis.net/om/1.0.0/om.xsd">
<gml:description xmlns:gml="http://www.opengis.net/gml">htb
data</gml:description>
<gml:name xmlns:gml="http://www.opengis.net/gml">Helsinki test bed
data</gml:name>
<om:member>
<om:Observation>
<om:samplingTime>
<gml:TimeInstant>
<gml:timePosition>20081127042000</gml:timePosition>
</gml:TimeInstant>
</om:samplingTime>
<om:procedure xlink:href="urn:ogc:def:procedure:temperature"/>
<om:observedProperty>temperature</om:observedProperty>
<om:result>
<gml:featureMember xmlns:gml="http://www.opengis.net/gml">
<gml:temperature>
<gml:boundedBy>
<gml:Envelope>
<gml:lowerCorner>25.399600 60.316000</gml:lowerCorner>
<gml:upperCorner>25.399600 60.316000</gml:upperCorner>
</gml:Envelope>
</gml:boundedBy>
<msGeometry>
<gml:Point>
<gml:pos>25.399600 60.316000</gml:pos>
</gml:Point>
</msGeometry>
<locationid>37</locationid>
<insertionTime>20081127042054</insertionTime>
<latitude>60.316</latitude>
<longitude>25.3996</longitude>
<leveltype>altitude</leveltype>
<levelvalue>17</levelvalue>
<levelunit>m</levelunit>
<version>1</version>
<parameterName>temperature</parameterName>
<value>-1.1</value>
<unit>C</unit>
<aggregationName>instant</aggregationName>
<aggregationValue>0</aggregationValue>
<aggregationUnit>n/a</aggregationUnit>
<form>n/a</form>
</gml:temperature>
</gml:featureMember>
</om:result>
</om:Observation>
</om:member>
</om:ObservationCollection>
View this message in context: http://n2.nabble.com/SOS-response-XML-validity-tp2335205p2335205.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
