[mapserver-users] Symbols Don't Follow Lines.
Moen, Paul T.
pmoen at nd.gov
Wed Feb 18 12:45:48 EST 2009
Changing the gap to a negative value fixed the problem. Thank you Steve.
On 2/18/09 11:29 AM, "Stephen Woodbridge" <woodbri at swoodbridge.com> wrote:
Paul,
Use GAP -7 to fix the problem.
-Steve W
Moen, Paul T. wrote:
> I forgot to mention the version.
> The output type is AGG and I see there was a problem with this. Does
> anybody if the version I am using has this problem?
> MapServer version 5.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
> SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> On 2/18/09 11:03 AM, "Paul Moen" <pmoen at nd.gov> wrote:
> I have two symbols that are used in a railroad layer. The railties
> symbol used to be aligned perpendicular to the line and therefore
> looked like railroad ties. The symbol now only draws upright, i.e.
> horizontal. The documentation at
> http://mapserver.org/mapfile/symbology/construction.html#sym-construction
> shows a layer and a symbol similar to what I have, except they use a
> T as the character, following the line. What changed and how do I
> get the symbol to follow the line again?
> SYMBOL
> NAME 'railties'
> TYPE TRUETYPE
> FONT "helvetica"
> CHARACTER "T"
> ANTIALIAS TRUE
> GAP 7
> END
> SYMBOL
> NAME 'circle'
> TYPE ELLIPSE
> POINTS 1 1 END
> FILLED TRUE
> END
> LAYER
> NAME "Railroads"
> DATA railroads
> GROUP "Transportation"
> TYPE LINE
> STATUS ON
> CLASS
> MAXSCALEDENOM 150000
> NAME "Railroads"
> STYLE
> SYMBOL 'circle'
> COLOR 0 0 0
> SIZE 2
> END
> OVERLAYSYMBOL 'railties'
> OVERLAYCOLOR 0 0 0
> OVERLAYSIZE 7
> END
> END
> Thanks,
> Paul
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090218/5d6fc372/attachment.html
