[mapserver-users] Problem with loading map file using C# map
script
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Wed Feb 18 14:35:31 EST 2009
I just allowed your message on the list so I am sure Tamas will get it.
Best regards,
Bart
Murty Maganti wrote:
> Sorry, it may be coming from our SMTP server. I will verify.
> *From:* Tamas Szekeres [mailto:szekerest at gmail.com]
> *Sent:* Wednesday, February 18, 2009 2:03 PM
> *To:* Murty Maganti
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] Problem with loading map file using
> C# map script
> Would you send me the files privately for the meantime?
> Tamas
> 2009/2/18 Murty Maganti <MMaganti at oriongis.com
> <mailto:MMaganti at oriongis.com>>
> Hi
> I have posted the test application. But the email is waiting for
> approval of moderator (as the attachment size is 75 KB and I think
> allowed is only 40 KB).
> Thanks
> Murty
> <mailto:szekerest at gmail.com>]
> *Sent:* Tuesday, February 17, 2009 6:33 PM
> *To:* Murty Maganti
> <mailto:mapserver-users at lists.osgeo.org>
> C# map script
> Hmmm. I haven't found such an issue before.
> If you could post an example that would be helpful to reproduce this.
> Best regards,
> Tamas
> Hi
> I have a issue loading a map file through map script and need help.
> I have two map info (tab) files with same name but in two different
> folders. I have two map files each containing each layer. I am loading
> these map files using C# map script (each map file is loaded in to a
> separate mapObj on a separate thread). At run time, when I debug the
> second mapObj, the layer has items (layerObj.getItem()) from the first
> layer loaded by the first map file. I verified 'shapepath' on mapObj
> and it is pointing to correct path. There is nothing wrong there. I am
> surprised how is it caching the item info, just by the file name (file
> name is same but they are completely from different folders).
> When I load the map file one more time (again a different .Net thread,
> it shows up correct fields).
> Within my app (Asp.Net), I can consistently replicate this.
> Thanks
> Murty
> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
