[mapserver-users] GDAL image handling band error with NetCDF WCS
layer
Roger André
randre at gmail.com
Wed Feb 18 17:24:54 EST 2009
Hi All,
- I am attempting to use a NetCDF file as a data source for a raster layer
in Mapserver. According to a very useful email sent in November 2005 from
Norman Barker,
http://lists.osgeo.org/pipermail/mapserver-users/2005-November/012153.html,
and from Mapserver documentation at
http://www.mapserver.org/ogc/wcs_format.html#netcdf, it seems like this
should be possible using Mapserver's gdal driver to read the file. However,
I am running into some problems when trying to implement his example.
- The NetCDF file which I am using is a "CF Convention" sample file which I
downloaded from
http://www.unidata.ucar.edu/software/netcdf/examples/tos_O1_2001-2002.nc.
This file contains information about sea-surface temperatures, and when
viewed by gdalinfo has the following characteristics:
$ gdalinfo tos_O1_2001-2002.nc
Driver: netCDF/Network Common Data Format
Files: tos_O1_2001-2002.nc
Size is 512, 512
Coordinate System is `'
Metadata:
NC_GLOBAL#title=IPSL model output prepared for IPCC Fourth Assessment
SRES A2 experiment
NC_GLOBAL#institution=IPSL (Institut Pierre Simon Laplace, Paris, France)
NC_GLOBAL#source=IPSL-CM4_v1 (2003) : atmosphere : LMDZ (IPSL-CM4_IPCC,
96x71x19) ; ocean ORCA2 (ipsl_cm4_v1_8, 2x2L31); sea ice LIM (ipsl_cm4_v
NC_GLOBAL#contact=Sebastien Denvil, sebastien.denvil at ipsl.jussieu.fr
NC_GLOBAL#project_id=IPCC Fourth Assessment
NC_GLOBAL#table_id=Table O1 (13 November 2004)
NC_GLOBAL#experiment_id=SRES A2 experiment
NC_GLOBAL#realization=1
NC_GLOBAL#cmor_version=9.600000e-01
NC_GLOBAL#Conventions=CF-1.0
NC_GLOBAL#history=YYYY/MM/JJ: data generated; YYYY/MM/JJ+1 data
transformed At 16:37:23 on 01/11/2005, CMOR rewrote data to comply with CF
standards and IPCC Fourth Assessment requirements
NC_GLOBAL#references=Dufresne et al, Journal of Climate, 2015, vol XX, p
136
NC_GLOBAL#comment=Test drive
Subdatasets:
SUBDATASET_1_NAME=NETCDF:"tos_O1_2001-2002.nc":lon_bnds
SUBDATASET_1_DESC=[180x2] lon_bnds (64-bit floating-point)
SUBDATASET_2_NAME=NETCDF:"tos_O1_2001-2002.nc":lat_bnds
SUBDATASET_2_DESC=[170x2] lat_bnds (64-bit floating-point)
SUBDATASET_3_NAME=NETCDF:"tos_O1_2001-2002.nc":time_bnds
SUBDATASET_3_DESC=[24x2] time_bnds (64-bit floating-point)
SUBDATASET_4_NAME=NETCDF:"tos_O1_2001-2002.nc":tos
SUBDATASET_4_DESC=[24x170x180] sea_surface_temperature (32-bit
floating-point)
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 512.0)
Upper Right ( 512.0, 0.0)
Lower Right ( 512.0, 512.0)
Center ( 256.0, 256.0)
- The SUBDATASET of interest is the "tos" one, and when queried by gdalinfo
it shows that it contains 24 bands, each of which varies by
NETCDF_DIMENSION_time that increments by 15. When specifically queried by
gdalinfo, this SUBDATASET looks like this:
$ gdalinfo NETCDF:"tos_O1_2001-2002.nc":tos
Files: none associated
Size is 180, 170
Origin = (0.000000000000000,90.000000000000000)
Pixel Size = (2.000000000000000,-1.000000000000000)
Metadata:
SRES A2 experiment
136
tos#standard_name=sea_surface_temperature
tos#long_name=Sea Surface Temperature
tos#units=K
tos#cell_methods=time: mean (interval: 30 minutes)
tos#_FillValue=1.000000e+20
tos#missing_value=1.000000e+20
tos#original_name=sosstsst
tos#original_units=degC
tos#history= At 16:37:23 on 01/11/2005: CMOR altered the data in the
following ways: added 2.73150E+02 to yield output units; Cyclical dimension
was output starting at a different lon;
lon#standard_name=longitude
lon#long_name=longitude
lon#units=degrees_east
lon#axis=X
lon#bounds=lon_bnds
lon#original_units=degrees_east
lat#standard_name=latitude
lat#long_name=latitude
lat#units=degrees_north
lat#axis=Y
lat#bounds=lat_bnds
lat#original_units=degrees_north
time#standard_name=time
time#long_name=time
time#units=days since 2001-1-1
time#axis=T
time#calendar=360_day
time#bounds=time_bnds
time#original_units=seconds since 2001-1-1
Corner Coordinates:
Upper Left ( 0.0000000, 90.0000000)
Lower Left ( 0.0000000, -80.0000000)
Upper Right ( 360.000, 90.000)
Lower Right ( 360.000, -80.000)
Center ( 180.0000000, 5.0000000)
Band 1 Block=180x1 Type=Float32, ColorInterp=Undefined
NoData Value=1.00000002004087734e+20
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=15
NETCDF_time_units=days since 2001-1-1
Band 2 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=45
Band 3 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=75
Band 4 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=105
Band 5 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=135
Band 6 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=165
Band 7 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=195
Band 8 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=225
Band 9 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=255
Band 10 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=285
Band 11 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=315
Band 12 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=345
Band 13 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=375
Band 14 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=405
Band 15 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=435
Band 16 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=465
Band 17 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=495
Band 18 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=525
Band 19 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=555
Band 20 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=585
Band 21 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=615
Band 22 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=645
Band 23 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=675
Band 24 Block=180x1 Type=Float32, ColorInterp=Undefined
Metadata:
NETCDF_VARNAME=tos
NETCDF_DIMENSION_time=705
- I have been able to setup a WCS implementation that returns a correct
DescribeCoverage response using the following request:
http://localhost/cgi-bin/mapserv?map=/var/www/mapfiles/netCDF/test.map
&SERVICE=WCS
&VERSION=1.0.0
&REQUEST=DescribeCoverage
&COVERAGE=netcdf
- However, I cannot seem to make a GetCoverage request work properly. Below
is an example of one that I've tried.
&SERVICE=wcs
&VERSION=1.0.0
&REQUEST=GetCoverage
&coverage=netcdf
&CRS=EPSG:4326
&BBOX=-179,-80,180,90
&WIDTH=1200
&HEIGHT=600
&FORMAT=GTiff
&RangeSubset=BandsName:bilinear[bands[1]]
- The error I get back is this:
<ServiceException>msGetGDALBandList(): Image handling error. Attempt to
operate on GDAL file with no bands, layer=netcdf.
</ServiceException>
- I'm not sure based on the structure of the NetCDF file how I should
structure the request, or if my mapfiles are correctly structured. Below
are my mapfiles:
- test.map:
MAP
NAME 'test'
EXTENT -180 -80 180 90
#EXTENT 0.0 -80.0 360.0 90.0
SIZE 600 600
IMAGECOLOR 0 0 0
PROJECTION
"init=epsg:4326"
END
# layers to include in map
INCLUDE 'netcdf.map'
# WEB PARAMETERS
WEB
IMAGEURL "/var/www/html/tmp"
IMAGEPATH "/tmp"
METADATA
"wcs_label" "GMap WCS Demo Server"
END
END
OUTPUTFORMAT
NAME 'GEOTIFF_FLOAT'
DRIVER "GDAL/GTiff"
MIMETYPE "image/tiff"
IMAGEMODE FLOAT32
EXTENSION "tif"
END
END
- netcdf.map:
# netcdf
LAYER
NAME "netcdf"
STATUS DEFAULT
TYPE RASTER
DUMP TRUE
DATA "tos_O1_2001-2002.nc"
METADATA
wcs_label "Test netCDF Server"
ows_extent '-180.0 -80.0 180.0 90.0'
#ows_extent '0.0 -80.0 360.0 90.0'
wcs_resolution '2 -1'
ows_srs "EPSG:4326"
wcs_formats "GEOTIFF_FLOAT"
wcs_nativeformat "netCDF"
wcs_bandcount "24"
wcs_rangeset_axes "bands"
wcs_rangeset_label "tos"
wcs_rangeset_name "bands"
END
END
- If anything jumps out at you, please let me know.
Thanks,
Roger
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090218/804c66f8/attachment-0001.html
