[mapserver-users] Edit mode in mapserver
Blaise
bpicinbono at worldonline.fr
Fri Feb 20 15:12:23 EST 2009
Hi there,
Hopefully, it IS possible to edit features with MapServer / MapScript. You
have to write your own functions. It works great.
Regards
Blaise
On Friday 20 February 2009 21:04, Alexandre Dube wrote:
> Hi Rohan,
> It is not possible to "edit" features with MapServer. You might want
> to take a look at one of theses projects that can : GeoServer, TinyOWS,
> FeatureServer.
> In a small demo I wrote, I use MapServer as my WMS server to render
> images and TinyOWS as my WFS server to return GML and to do my
> transactional stuff ( insert/update/delete ) and finally OpenLayers as
> my client UI. Both MapServer and TinyOWS read the "road" data from a
> PostGIS database ( required with TinyOWS ). See the demo below (1).
> Hope this gives you some clues/ideas for your project.
> Regards,
> Alexandre
> (1) http://dev4.mapgears.com/bdga/bdgaWFS-T.html
> (2)
> http://dev.openlayers.org/sandbox/topp/wfs/examples/wfs-protocol-transactio
>ns.html
> rohan phatak wrote:
> > Hello Friends,
> > I am using Mapserver Application Gmap in which .map file is using. I
> > am trying to develop "Information System" & I want to publish these
> > map to other computers & i want to give 'edit' mode for user means if
> > user see any new feature then he can insert point/line/polygon data in
> > it with attribute information. ( the relationship is like Server-Client)
> > So how to do this??
> > 1. Is PHP/ mapscript will useful Or
> > 2. Is there any inbuilt application to do these??
> > at a time only one user can use edit mode.
> > thanks a lot !!
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
