[mapserver-users] MapServer problem
Kralidis,Tom [Ontario]
Tom.Kralidis at ec.gc.ca
Mon Feb 23 13:48:35 EST 2009
> Hi Mapserver users,
> I am trying to display few points on the browser using
> Mapserver. I have created MySQL database and created
> connection with mapserver by the help of .ovf xml file.
> <OGRVRTDataSource>
> <OGRVRTLayer name="nsdb">
> <SrcDataSource>MYSQL:dispro,user=uuuuuu,password=pppp,host=192
> .170.1.100,port=3306,tables=STATION</SrcDataSource>
> <SrcSQL>SELECT absnum, stlat, stlon, stflag FROM
> STATION</SrcSQL>
> <GeometryType>wkbPoint</GeometryType>
> <GeometryField encoding="PointFromColumns" x="stlon"
> y="stlat"/>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> When I run the command :
> ogrinfo /mnt/fritjof/wms/nsdb/con.ovf
> ogrinfo returns :
> ERROR 4: Update access not supported for VRT datasources.
> Had to open data source read-only.
> INFO: Open of `/mnt/fritjof/wms/nsdb/con.ovf'
> using driver `VRT' successful.
> 1: nsdb (Point)
> Version details of mapserver and GDAL as follows:
> $ ./mapserv -v
> MapServer version 4.10.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=PDF OUTPUT=SVG SUPPORTS=PROJ
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=THREADS INPUT=EPPL7 INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> $ gdal-config --version
> 1.5.3
> - Show quoted text -
> I have a map file con.map as follows:
> MAP
> NAME "MYSQL-TEST"
> EXTENT -180 -90 180 90
> UNITS dd
> CONFIG "CPL_DEBUG" "ON"
> PROJECTION
> "init=epsg:4326"
> END
> SHAPEPATH "/mnt/fritjof/wms/nsdb"
> LAYER
> DEBUG ON
> METADATA
> "wms_title" "nsdb"
> "wms_srs" "EPSG:4326"
> "wms_extent" "-57.768 64.1842 -51.6283 64.3645"
> END
> NAME "stations"
> STATUS DEFAULT
> TYPE POINT
> CONNECTIONTYPE OGR
> CONNECTION "con.ovf"
> DATA "nsdb"
> PROJECTION
> "init=epsg:4326"
> END
> EXTENT -57.768 64.1842 -51.6283 64.3645
> CLASS
> NAME "MyClass"
> STYLE
> SYMBOL 1
> SIZE 15
> COLOR 255 0 0
> END
> END
> END
> END
You're pointing to a SYMBOL that doesn't exist. Either comment that
out, or make sure your mapfile references a SYMBOLSET file.
..Tom
> And I have another html form from where I am trying to
> display in browser the Latitude and longitude points which
> are stored in database.
> MAPFILE
> REQUEST
> SERVICE
> VERSION
> LAYERS
> STYLES
> SRS
> BBOX
> WIDTH
> HEIGHT
> FORMAT
> But Mapserver is displaying nothing and does not giving any
> error. Just it's showing a blank map. Could you tell me Why??
> What's the problem may be happen??
> Thanking you.
> Regards,
> Phalguni
