VS: [mapserver-users] WMS problem
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Feb 27 07:42:01 EST 2009
It is for sure possible to fix your problem, but because MapLab is no more supported or developed in any way I would suggest you to select some other application to play with. I could guess that there is nothing wrong with your Mapserver configuration because you do see the image in the beginning. Zooming problems are most probably caused by MapLab and struggling with is would of course be educational but if you are searching for some permanent system, go and get a fresh Mapserver version (5.2 or 5.4 beta) and choose another client.
-Jukka Rahkonen-
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Andrea Ardito
Lähetetty: 27. helmikuuta 2009 13:49
Vastaanottaja: mapserver-users
Kopio: Mattia Ferrari; Edgardo Ghibaudo
Aihe: Re: [mapserver-users] WMS problem
Hi Pietro,
1.I've tried to invoke mapserver in cgi mode and it seems ok.
http://webgis.provincia.biella.it/cgi-bin/mapserv?map=/opt/fgs/apps/mapservergeo/map/basewms.map&mode=map&layer=stati
2. We looked on the apache log file and we fixed some errors we had in a php file.
Anyway things are not changed.
http://webgis.provincia.biella.it/apps/maplab/projects/gmf_apps/basewms4/wmdmap.php
Please, do you have anything else to suggest?
Thank you very much for your help
ciao
andrea
arch. Andrea ARDITO
Sistema Informativo Territoriale Ambientale (S.I.T.A.)
Settore Pianificazione e Sicurezza del Territorio
Provincia di Biella
Via Quintino Sella, 12 - 13900 BIELLA
tel. 015.8480880
fax. 015.8480740
-----Original Message-----
To: mapserver-users <mapserver-users at lists.osgeo.org>
Date: Thu, 26 Feb 2009 16:11:41 +0100
Subject: Re: [mapserver-users] WMS problem
Hi Andrea,
1. no
2. no matters
3. It is difficult to answer...
If the problem is EXTENT & PROJECTION, remember that a .map file has the PROJECTION set at map level and PROJECTIONs set at layers level; the map Projection is the projection system of the result of the map (i.e. the map image), the layer Projection is the projection system of the data source of the layer. If a layer datasource projection differs from the map projection, you must to set it, otherwise ms try to project the data according with map projection.
Try invoke mapserver in cgi mode to see the results: http://the.host/cgi-bin/mapserv?map=/path/of/the.map&mode=map&layer= ...
Imho your problem isn't the map, but occurs in your php script. Take a look on the php error log: it is a text file, its path is set in your php.ini file (error_log directive, can be an absolute or relative path)
4. obviously scale is nonsense when using non-projected reference systems like epsg:4326, but mapserver does not know.
hth
ciao
....................pg
-- Pietro Giannini Bytewise srl - Area GIS 41°50'38.58"N
12°29'13.39"E
Andrea Ardito ha scritto:
Hi, we have this system working with MapServer version 4.8.2, PHP version
4.4.2. I am trying to do a map that shows both layer (WGS84 shapefile) and
WMS data togheter. The starting response is ok, but I get the blank image
from the first pan or zoom on. This is the example URL:
http://webgis.provincia.biella.it/apps/maplab/projects/gmf_apps/basewms4/wmdmap.php <http://webgis.provincia.biella.it/apps/maplab/projects/gmf_apps/basewms4/wmdmap.php>
I guess the problem is due to wrong parameters for EXTENT, SIZE and
PROJECTION in the mapfile. These are: EXTENT -15 25 40 70 SIZE 470 520
PROJECTION "init=epsg:4326". The question are: 1. the SIZE (in pixel) has
to be proportional to the EXTENT? 2. if yes, how to obtain the right values
for the EXTENT? 3. if not, where is the problem? 4. in a map with geographic
non-projected data like this, is correct to have value for scale of the
representation since UNITS are DD? I would be very grateful for any help
from you all, thanks! Best regards andrea ardito P.S. If I set no layer in
the map file, and I try to represent only WMS layer (adding them from
"Servizi WMS" button), it works.
arch. Andrea ARDITO
Provincia di Biella
tel. 015.8480880
fax. 015.8480740
--http://www.provincia.biella.it------------------------------------------------------
Vuoi rimanere sempre aggiornato sulle nostre attivita'?
Visita la pagina dei feed RSS sul nostro sito ed iscriviti alla sezione di interesse.
--Avviso------------------------------------------------------------------------------
Questo messaggio e i suoi allegati sono riservati esclusivamente alle persone in
indirizzo e possono contenere informazioni confidenziali. Se questo messaggio vi e'
pervenuto per errore, vi informiamo che ogni suo uso e'proibito.
In questo caso rispedite immediatamente il messaggio al mittente e cancellatelo.
Per ogni chiarimento contattateci scrivendo a ced at provincia.biella.it.
Grazie -Il Webmaster.
--Warning-----------------------------------------------------------------------------
This message and its attachments are addressed solely to the persons above and may
contain confidential information. If you have received the message in error, be
informed that any use of the content hereof is prohibited.
Please return it immediately to the sender and delete the message. Should you have
any questions, please contact us by replying to ced at provincia.biella.it.
The Webmaster.
_______________________________________________ mapserver-users mailing list
mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users <http://lists.osgeo.org/mailman/listinfo/mapserver-users>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090227/48e0e54e/attachment.html
