[mapserver-users] Re: WCS that reads NetCDF files returns "Image
handling error. Attempt to operate on GDAL file with no bands"
Roger André
randre at gmail.com
Fri Feb 27 15:53:37 EST 2009
Alright, found a promising lead in
http://trac.osgeo.org/mapserver/ticket/2462. It appears that the DATA
parameter for the layer needs to specify more than just the filename
of the netcdf. Using the syntax below returns a GeoTIFF.
DATA "netCDF:/var/www/mapfiles/netCDF/sresa1b_ncar_ccsm3_0_run1_200001.nc:tas"
Now need to figure out how to work with the extents.
On Fri, Feb 27, 2009 at 11:40 AM, Roger André <randre at gmail.com> wrote:
> Hi Norman,
> Sorry for the direct email, but much of the relevant documentation
> that I have found regarding this topic appears to have been written by
> you. I'm hoping you can take the time to share a bit more of your
> wisdom regarding this.
> I would like to setup a Mapserver WCS service that reads a single
> netCDF file as the data source. Later on I'd like to get fancy and
> read multiple files as a tileindex, with multiple time slices in them,
> but for now I am just trying to read a single file with a one-band
> data layer in it. I am using the example you posted on the Mapserver
> website, http://mapserver.org/ogc/wcs_format.html, as well as an old
> post from you -
> http://lists.osgeo.org/pipermail/mapserver-users/2005-November/012153.html.
> The examples are great, but I'm having trouble adapting them to my
> sample data.
> I have downloaded a CF convention netCDF file from
> http://www.unidata.ucar.edu/software/netcdf/examples/sresa1b_ncar_ccsm3_0_run1_200001.nc,
> which contains a SUBDATASET named "tas". This SUBDATASET contains
> only a single band, which when queried by gdalinfo looks like this
> (Note: I have omitted the Metadata for clarity.)
> $ gdalinfo NETCDF:"sresa1b_ncar_ccsm3_0_run1_200001.nc":tas
> Warning 1: Latitude grid not spaced evenly.
> Seting projection for grid spacing is within 0.1 degrees threshold.
> Driver: netCDF/Network Common Data Format
> Files: none associated
> Size is 256, 128
> Coordinate System is `'
> Origin = (-0.703125000000000,89.627952755905511)
> Pixel Size = (1.406250000000000,-1.400436761811024)
> Corner Coordinates:
> Upper Left ( -0.7031250, 89.6279528)
> Lower Left ( -0.7031250, -89.6279528)
> Upper Right ( 359.297, 89.628)
> Lower Right ( 359.297, -89.628)
> Center ( 179.2968750, 0.0000000)
> Band 1 Block=256x1 Type=Float32, ColorInterp=Undefined
> NoData Value=1.00000002004087734e+20
> Metadata:
> NETCDF_VARNAME=tas
> NETCDF_DIMENSION_time=730136
> NETCDF_time_units=days since 0000-1-1
> I have setup a mapfile to read this file/layer which looks like this:
> MAP
> NAME 'netcdf'
> OUTPUTFORMAT
> NAME "GEOTIFF_FLOAT"
> DRIVER 'GDAL/GTiff'
> MIMETYPE 'image/tiff'
> IMAGEMODE FLOAT32
> EXTENSION 'tif'
> END
> LAYER
> NAME "tas"
> STATUS OFF
> TYPE RASTER
> DUMP TRUE
> DATA "sresa1b_ncar_ccsm3_0_run1_200001.nc"
> METADATA
> wcs_label "Test netCDF Server"
> ows_extent '-0.7031250 -89.6279528 359.297 89.628' # <-- 0 to 360?
> wcs_resolution '1.406250000000000 -1.400436761811024'
> ows_srs "EPSG:4326" # <-- Not sure about this
> wcs_formats "GEOTIFF_FLOAT"
> wcs_nativeformat "netCDF"
> wcs_bandcount "1" # <-- Not sure about this
> wcs_rangeset_axes "bands"
> wcs_rangeset_label "Atmospheric Levels"
> wcs_rangeset_name "tas" # <-- Not sure about this
> END # end metadata
> END # end layer
> END # map
> I took a stab at what the wcs and ows entries should look like in the
> METADATA section, but I'm not at all sure I got them right. For
> example, the geographic extents of all the netCDF files I have seen so
> far seem to use a 0 - 360 longitude range. I'm not really sure how to
> reconcile this with the ows_srs of EPSG:4326, of how to properly list
> the extents. I used what gdalinfo reports, thinking that since gdal
> would be reading the file, the info should match.
> With this mapfile, I am able to execute a DescribeCoverage request
> using the following command:
> http://localhost/cgi-bin/mapserv?map=/var/www/mapfiles/netCDF/netcdf.map
> &SERVICE=WCS
> &VERSION=1.0.0
> &REQUEST=DescribeCoverage
> &COVERAGE=tas
> I've attached the XML that is returned, it appears to be reasonable,
> but whether it is correct or not, I'm not sure. What is certain
> though, is that when I try to make a GetCoverage request, I get back a
> consistent error that says "Attempt to operate on GDAL file with no
> bands, layer=tas". My GetCoverage request looks like this:
> &SERVICE=wcs
> &VERSION=1.0.0
> &REQUEST=GetCoverage
> &coverage=tas
> &CRS=EPSG:4326
> &BBOX=-0.703125,-89.6279528,359.297,89.628
> &WIDTH=600
> &HEIGHT=600
> &FORMAT=image/tiff
> The error that is returned looks like this:
> <?xml version='1.0' encoding="ISO-8859-1" ?>
> <ServiceExceptionReport version="1.2.0"
> xmlns="http://www.opengis.net/ogc"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/ogc
> http://schemas.opengis.net/wcs/1.0.0/OGC-exception.xsd">
> <ServiceException>msGetGDALBandList(): Image handling error. Attempt
> to operate on GDAL file with no bands, layer=tas.
> </ServiceException>
> </ServiceExceptionReport>
> And now I am stuck. Since there are quite a few different parameters
> that need to be set, I'm not sure which of them I've messed up.
> Thanks in advance for any assistance you could provide with this.
> Roger
