[mapserver-users] Trouble with mode=tile
Dave Rafkind
drafkind at traversetechnologies.com
Fri Jan 2 15:06:09 EST 2009
Thanks for the suggestions, but I don't think that's quite it:
1 - removing "epsg:4326" from the wms_srs part of the mapfile didn't fix it
2 - adding "&SRS=EPSG:900913" to the Virtual Earth "tileSource" string
didn't fix it
Is there anything else I can try?
Fawcett, David wrote:
> Dave,
> I am not sure if this is it, but in your WMS request, you are not
> specifying a SRS. You are advertising two SRS' in your WEB WMS
> "wms_srs" metadata. I wonder if MapServer is just defaulting to the
> first SRS in your list in the absence of an explicit request?
> David.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Dave
> Rafkind
> Sent: Friday, January 02, 2009 12:39 PM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] Trouble with mode=tile
> Hi list, I'm using the latest ms4w on a windows XP box. When trying to
> use mapserver's tile mode in a Virtual Earth or Google Maps control, it
> looks totally wrong (like the wrong projection is being used
> perhaps?). What is the right way to go about this?
> Here's mapserver.exe -v:
> C:\ms4w\Apache\cgi-bin>mapserv -v
> MapServer version 5.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF
> OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
> SUPPORTS=ICO
> NV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
> SUPPORTS=FASTCGI SUP
> PORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS
> INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> Here's the relevant part of my web page with the map control:
> map=new VEMap('myMap');
> var layerId = "myCustomTileLayer";
> var tileSource =
> "http://localhost/cgi-bin/mapserv.exe?map=/src/maps/mapdata/maps/dave1.m
> ap&layers=world&mode=tile&tilemode=ve&tile=%4";
> var tileSourceSpec = new VETileSourceSpecification(layerId,
> tileSource);
> Here's the last line of my EPSG file (from c:\ms4w\proj\nad\epsg)
> # google/virtual earth spherical mercator
> <900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0
> +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs <>
> And here's my map file:
> MAP
> IMAGETYPE PNG
> OUTPUTFORMAT
> NAME png
> DRIVER "GD/PNG"
> MIMETYPE "image/png"
> IMAGEMODE RGBA
> EXTENSION "png"
> TRANSPARENT ON
> END
> SHAPEPATH "/src/maps/mapdata"
> FONTSET "/src/maps/mapdata/fonts.list"
> IMAGECOLOR 0 0 0
> WEB
> METADATA
> "wms_title" "WMS Demo Server"
> "wms_onlineresource"
> ap&"
> "wms_srs" "EPSG:4326 EPSG:900913"
> END
> END
> PROJECTION
> "init=epsg:900913"
> END
> SYMBOL
> name "circle"
> type ellipse
> filled true
> POINTS 1 1 END
> END
> SYMBOL
> NAME 'dashed1'
> TYPE ELLIPSE
> POINTS 1 1 END
> FILLED true
> STYLE 4 4 END
> END
> SYMBOL
> NAME 'railway'
> TYPE cartoline
> LINECAP butt
> LINEJOIN miter
> LINEJOINMAXSIZE 3
> STYLE
> 1 10 1 10
> END
> END
> LAYER
> PROJECTION
> "init=epsg:4326"
> END
> NAME world
> DATA "world/world_adm0.shp"
> STATUS OFF
> TYPE LINE
> LABELITEM "REGION"
> CLASS
> STYLE
> COLOR 255 255 255
> OUTLINECOLOR 0 0 0
> END
> LABEL
> COLOR 0 0 0
> OUTLINECOLOR 255 255 255
> TYPE TRUETYPE
> FONT arial
> SIZE 9
> ANTIALIAS TRUE
> PARTIALS FALSE
> MINDISTANCE 250
> BUFFER 4
> END
> END
> END
> END
