[mapserver-users] Trouble with mode=tile
Paul Ramsey
pramsey at cleverelephant.ca
Fri Jan 2 15:59:12 EST 2009
Dave,
- Remove the PROJECTION block from the MAP level (leave the one at the
LAYER level). Tile mode constructs its own output projection object,
it doesn't need map file configuration for the output projection, just
the inputs.
- Confirm that the shape file you are using *is* in fact epsg:4326
- Try manually accessing the service using tile=0 or tile=1, and see
what comes back
- Show some pictures of "wrong" in your next mail
P.
On Fri, Jan 2, 2009 at 12:06 PM, Dave Rafkind
<drafkind at traversetechnologies.com> wrote:
> Thanks for the suggestions, but I don't think that's quite it:
> 1 - removing "epsg:4326" from the wms_srs part of the mapfile didn't fix it
> 2 - adding "&SRS=EPSG:900913" to the Virtual Earth "tileSource" string
> didn't fix it
> Is there anything else I can try?
> Fawcett, David wrote:
>> Dave,
>> I am not sure if this is it, but in your WMS request, you are not
>> specifying a SRS. You are advertising two SRS' in your WEB WMS
>> "wms_srs" metadata. I wonder if MapServer is just defaulting to the
>> first SRS in your list in the absence of an explicit request?
>> David.
>> -----Original Message-----
>> From: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Dave
>> Rafkind
>> Sent: Friday, January 02, 2009 12:39 PM
>> To: mapserver-users at lists.osgeo.org
>> Subject: [mapserver-users] Trouble with mode=tile
>> Hi list, I'm using the latest ms4w on a windows XP box. When trying to use
>> mapserver's tile mode in a Virtual Earth or Google Maps control, it
>> looks totally wrong (like the wrong projection is being used perhaps?).
>> What is the right way to go about this?
>> Here's mapserver.exe -v:
>> C:\ms4w\Apache\cgi-bin>mapserv -v
>> MapServer version 5.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> OUTPUT=PDF
>> OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
>> SUPPORTS=ICO
>> NV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>> SUPPORTS=WFS_SERVER
>> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
>> SUPPORTS=FASTCGI SUP
>> PORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS
>> INPUT=OGR
>> INPUT=GDAL INPUT=SHAPEFILE
>> Here's the relevant part of my web page with the map control:
>> map=new VEMap('myMap');
>> var layerId = "myCustomTileLayer";
>> var tileSource =
>> "http://localhost/cgi-bin/mapserv.exe?map=/src/maps/mapdata/maps/dave1.m
>> ap&layers=world&mode=tile&tilemode=ve&tile=%4";
>> var tileSourceSpec = new VETileSourceSpecification(layerId,
>> tileSource);
>> Here's the last line of my EPSG file (from c:\ms4w\proj\nad\epsg)
>> # google/virtual earth spherical mercator
>> <900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0
>> +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs <>
>> And here's my map file:
>> MAP
>> IMAGETYPE PNG
>> OUTPUTFORMAT
>> NAME png
>> DRIVER "GD/PNG"
>> MIMETYPE "image/png"
>> IMAGEMODE RGBA
>> EXTENSION "png"
>> TRANSPARENT ON
>> END
>> SHAPEPATH "/src/maps/mapdata"
>> FONTSET "/src/maps/mapdata/fonts.list"
>> IMAGECOLOR 0 0 0
>> WEB
>> METADATA
>> "wms_title" "WMS Demo Server"
>> "wms_onlineresource"
>> ap&"
>> "wms_srs" "EPSG:4326 EPSG:900913"
>> END
>> END
>> PROJECTION
>> "init=epsg:900913"
>> END
>> SYMBOL
>> name "circle"
>> type ellipse
>> filled true
>> POINTS 1 1 END
>> END
>> SYMBOL
>> NAME 'dashed1'
>> TYPE ELLIPSE
>> POINTS 1 1 END
>> FILLED true
>> STYLE 4 4 END
>> END
>> SYMBOL
>> NAME 'railway'
>> TYPE cartoline
>> LINECAP butt
>> LINEJOIN miter
>> LINEJOINMAXSIZE 3
>> STYLE
>> 1 10 1 10
>> END
>> END
>> LAYER
>> PROJECTION
>> "init=epsg:4326"
>> END
>> NAME world
>> DATA "world/world_adm0.shp"
>> STATUS OFF
>> TYPE LINE
>> LABELITEM "REGION"
>> CLASS
>> STYLE
>> COLOR 255 255 255
>> OUTLINECOLOR 0 0 0
>> END
>> LABEL
>> COLOR 0 0 0
>> OUTLINECOLOR 255 255 255
>> TYPE TRUETYPE
>> FONT arial
>> SIZE 9
>> ANTIALIAS TRUE
>> PARTIALS FALSE
>> MINDISTANCE 250
>> BUFFER 4
>> END
>> END
>> END
>> END
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
