[mapserver-users] Path for errorfile
Ben Madin
ben at remoteinformation.com.au
Mon Jan 5 07:11:20 EST 2009
G'day all,
as a negative, Can you not use a relative reference for the errorfile?
for example, using :
CONFIG "MS_ERRORFILE" "/Users/19022662/Sites/marketprices/
mapserver/mserr.log"
DEBUG 4
works as expected, writing copious quantities to the log.
using :
CONFIG "MS_ERRORFILE" "mserr.log"
DEBUG 4
does not, although both the .log file and the .map file are in the /
Users/19022662/Sites/marketprices/mapserver/ directory. Relative paths
work fine for symbol files, data etc.
I also note that the RFC28 refers to setting this :
It will be possible to specify MS_ERRORFILE either as an environment
variable or via a CONFIG directive inside a mapfile:
CONFIG "MS_ERRORFILE" "/tmp/mapserver.log"
or
CONFIG "MS_ERRORFILE" "stderr"
but doesn't specify whether or not a relative path could be used.
This is inconsistent with all other specifications of path, can/should
it be amended? Should I file this as a bug?
cheers
Ben
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome WA 6725
Out here, it pays to know...
