[mapserver-users] Showing pop up for a line
Dan Little
danlittle at yahoo.com
Tue Jan 6 10:52:17 EST 2009
You may also want to use mapserver to render the lines as a raster layer instead of vector.
----- Original Message ----
> From: Steve Lime <Steve.Lime at dnr.state.mn.us>
> To: Subha Ramakrishnan <subha at gslab.com>
> Cc: mapserver-users at lists.osgeo.org
> Sent: Tuesday, January 6, 2009 9:31:18 AM
> Subject: Re: [mapserver-users] Showing pop up for a line
> Why not use straight MapServer queries? Set a reasonable tolerance and that
> should
> work ok too.
> Steve
> >>> On 1/6/2009 at 12:04 AM, in message <4962F45D.3010103 at gslab.com>, Subha
> Ramakrishnan wrote:
> > Hi,
> > I am using Mapserver 5.0.2 with Openlayers.
> > I've a line layer (from mapserver) shown on my base map(google physical).
> > Now, when i click on a line, i want to show a pop using openlayers.
> > I am able to do this for a polygon layer. I send the lat,lon of the
> > point that is clicked and use the postgis query
> > "ST_Contains(topology,geomFromText('POINT(77.87117958068927
> > 13.491965860913544)',-1))" to find the polygon (and fetch the polygon
> > specific data to show on pop up) and attach the Openlayers popup to the
> > point clicked.
> > I am not able to do this for a line layer as the postgis query doesn't
> > return anything.
> > I tried this query also,
> > 13.491965860913544)',-1)) AND
> > distance(topology,geomFromText('POINT(77.87117958068927
> > 13.491965860913544)',-1)) <= 1" but it doesn't work.
> > Does any one know how to check if a point is a part of a line or if
> > there is any other way to show the pop up?
> > Thanks a lot for the help.
> > Regards,
> > Subha
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
