[mapserver-users] Confirmation of status of UTF8 support, and
where transcoding to Latin-1 may be happening.
Russell McOrmond
russell at flora.ca
Tue Jan 6 13:12:30 EST 2009
I hope people don't mind me posting as I learn things, hoping that it
will spark some ideas from other people.
On Sun, 4 Jan 2009, Russell McOrmond wrote:
> Howard Butler wrote on November 24, 2008 @ 05:17 PM:
>> pictures looked right. The problem might be as simple as the function
>> msConvertWideStringToUTF8 being broken. Here's where MapServer tries to
>> convert it:
>> http://trac.osgeo.org/mapserver/browser/trunk/mapserver/mapsde.c#L750
> The more I look at this, the more confused I get.
I'm now back at the customer (Xmas break), and confirmed that I'm not
even making use of this code. The relevant strings are SE_STRING_TYPE and
not SE_NSTRING_TYPE. I have also confirmed ( msDebug() statements) that
the characters coming out of SE_stream_get_string() are Latin-1 encoded,
and not UTF-8 encoded.
Our database person confirmed that the data is encoded as UTF-8 in the
database. This suggests to me that it is SDE itself or the libsde.so
client library that is doing the transcoding to Latin-1
I'm curious if anyone knows if libsde.so has an equivalent to Oracle's
NLS_LANG environment variable?
It seems the decision to use STRING rather than NSTRING came down to the
label functions. I haven't looked at those functions yet to determine if
they need Latin-1, and thus this is why things are working with STRING
(Which comes in as Latin-1) rather than NSTRING (Which the code suggests
should be transcoded to UTF-8).
Another issue, this time with iconv. I know this is not a mapserver
issue, but it is possible that someone has seen something similar.
We created some tables with strings in NSTRING. I then got the error
"msConvertWideStringToUTF8(): General error message. Encoding not
supported by libiconv(UTF-16)"
I'm a bit stuck as any call to iconv_open() returns -1, no matter what I
put for the from and to. The manual for iconv_open says that if it
returns -1 that it sets errno, but it doesn't change the value.
errno = 1;
cd = iconv_open("ISO-8859-1", "UTF-8");
msDebug("errno= %d cd=%d\n",errno,cd);
errno= 1 cd=-1
errno = 5;
cd = iconv_open("UTF-8", "UTF-16");
errno= 5 cd=-1
errno = 123;
cd = iconv_open("", "UTF-16");
errno= 123 cd=-1
I've tried loading the gnu iconv first,
export LD_PRELOAD=/server/ndevl18/apache-2.2.9/lib/preloadable_libiconv.so
ldd then shows that library first, but no difference.
When I use the command line 'iconv' utility, it can convert from UTF-8
to ISO-8859-1 with no problem.
Has anyone seen a problem like this?
OS: Red Hat Enterprise Linux ES release 4 (Nahant Update 4)
ICONV: http://ftp.gnu.org/pub/gnu/libiconv/libiconv-1.12.tar.gz
> familiarity at this point) figure out what is going. It is a patch to
> msEncodeHTMLEntities to encode these characters. As entities they will work
> as the browser won't care what encoding it thinks the page should be in.
> I added the patch here: http://trac.osgeo.org/mapserver/ticket/2842
Turns out that while this solves my getFeatureInfo problem, it
introduces more problems. The various .map files have strings in them
that are UTF-8 encoded. In this situatuation we have words like
"générale" coming out as "générale" when we do a
request=getcapabilities
Seems things are never as simple as you first think.
Russell McOrmond, Internet Consultant: <http://www.flora.ca/>
Please help us tell the Canadian Parliament to protect our property
rights as owners of Information Technology. Sign the petition!
http://digital-copyright.ca/petition/ict/ http://KillBillC61.ca
"The government, lobbied by legacy copyright holders and hardware
manufacturers, can pry control over my camcorder, computer,
home theatre, or portable media player from my cold dead hands!"
