[mapserver-users] queryByRect throws an error
Murty Maganti
MMaganti at oriongis.com
Tue Jan 6 18:31:02 EST 2009
Hi Tamas
Thanks for reply.
These are extracts from my code to replicate the issue
//Create map object
mapObj map = new mapObj("MyMap.map");
//draw map
map.draw() ;
//Make sure some template name is defined. Otherwise, query will not be
successful.
for (int i = 0; i < map.numlayers; i++)
if (string.IsNullOrEmpty(m_map.getLayer(i).template))
m_map.getLayer(i).template = "abc";
//Perform the query now
map.queryByRect(map.extents);
I think after a call to map.draw(), a new layer '__embed__scalebar' is
added to layers collection. Setting template name to it is performing
the query on scalebar layer as well.
I think the scalebar layer is not satisfying these two conditions in
msQueryByRect method of mapquery.c and hence getting used for query
if(!msIsLayerQueryable(lp)) continue;
if(lp->status == MS_OFF) continue;
Please let me know if you need more info or you need any test
application.
Thanks
Murty
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Tuesday, January 06, 2009 3:33 PM
To: Murty Maganti
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] queryByRect throws an error
Could you provide a code/mapfile sample to reconstruct the issue? I've
never experienced such a problem, I've used this function many times
though.
Best regards,
Tamas
2009/1/6 Murty Maganti <MMaganti at oriongis.com>
mapObj.queryByRect(...) (using C# map script) is throwing following
exception when there is an embedded scale bar on map.
Exception message: "msShapefileOpen(): Unable to access file. No (NULL)
filename provided.;msBuildPath: Unable to access file"
Removing the scale bar from map file works fine.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090106/d8476b6a/attachment.html
