[mapserver-users] error compilation for mapserver 5.2.1
Tamas Szekeres
szekerest at gmail.com
Wed Jan 7 17:42:45 EST 2009
Hi Ionut,
I'm guessing the library files and the includes you're compiling against
might not relate to the same version. Could you provide a diff how you alter
nmake.opt when compiling mapserver? Do you use the Visual Studio Command
prompt or set up the environment manually (like using vcvars32.bat or
something).
Best regards,
Tamas
2009/1/7 sandric ionut <sandricionut at yahoo.com>
> Hello:
> I try to compile mapserver 5.2.1. using Microsoft Visual Studio 2005. I
> have made the proper modifications to the nmake.opt file and run the compile
> command as:
> nmake -f makefile.vc charp
> After several errors (which I've managed to pass), I've the following error
> (see bellow)
> How can I correct this?
> Thank you in advance
> Ionut
> -DUSE_THREAD -DIGNORE_MISSING_DATA -DENABLE_STDERR_DEBUG
> -DUSE_
> GD_ANTIALIAS -DUSE_ZLIB -DUSE_AGG -DWIN32 -D_WIN32 /c
> mapraster.c /Fo
> mapraster.obj
> mapraster.c
> C:\Program Files\Microsoft Visual Studio
> 8\VC\PlatformSDK\include\winnt.h(327) :
> warning C4005: 'TEXT' : macro redefinition
> h:\kit\mapserver-5.2.1\mapfile.h(123) : see previous definition of
> 'TEXT
> 8\VC\PlatformSDK\include\windef.h(343)
> : error C2059: syntax error : 'constant'
> 8\VC\PlatformSDK\include\windef.h(345)
> 8\VC\PlatformSDK\include\windef.h(346)
> 8\VC\PlatformSDK\include\windef.h(357)
> 8\VC\PlatformSDK\include\wingdi.h(98) :
> warning C4005: 'ERROR' : macro redefinition
> h:\kit\mapserver-5.2.1\mapfile.h(52) : see previous definition of
> 'ERROR
> 8\VC\PlatformSDK\include\wingdi.h(879)
> : error C2061: syntax error : identifier 'SIZEL'
> 8\VC\PlatformSDK\include\wingdi.h(880)
> : error C2061: syntax error : identifier 'szlMillimeters'
> : error C2059: syntax error : ';'
> 8\VC\PlatformSDK\include\wingdi.h(890)
> : error C2061: syntax error : identifier 'szlMicrometers'
> 8\VC\PlatformSDK\include\wingdi.h(893)
> : error C2059: syntax error : '}'
> 8\VC\PlatformSDK\include\wingdi.h(1103)
> 8\VC\PlatformSDK\include\wingdi.h(1104)
> 8\VC\PlatformSDK\include\wingdi.h(1105)
> 8\VC\PlatformSDK\include\wingdi.h(1106)
> 8\VC\PlatformSDK\include\wingdi.h(1557)
> : warning C4005: 'TRANSPARENT' : macro redefinition
> h:\kit\mapserver-5.2.1\mapfile.h(130) : see previous definition of
> 'TRAN
> SPARENT'
> 8\VC\PlatformSDK\include\wingdi.h(3025)
> : error C2146: syntax error : missing ')' before identifier 'lpsize'
> : error C2081: 'LPSIZE' : name in formal parameter list illegal
> : error C2061: syntax error : identifier 'lpsize'
> : error C2059: syntax error : ')'
> 8\VC\PlatformSDK\include\wingdi.h(3049)
> 8\VC\PlatformSDK\include\wingdi.h(3203)
> : error C2146: syntax error : missing ')' before identifier 'lpsz'
> : error C2061: syntax error : identifier 'lpsz'
> 8\VC\PlatformSDK\include\wingdi.h(3204)
> 8\VC\PlatformSDK\include\wingdi.h(3212)
> 8\VC\PlatformSDK\include\wingdi.h(3213)
> 8\VC\PlatformSDK\include\wingdi.h(3227)
> : error C2146: syntax error : missing ')' before identifier 'psizl'
> : error C2061: syntax error : identifier 'psizl'
> 8\VC\PlatformSDK\include\wingdi.h(3228)
> 8\VC\PlatformSDK\include\wingdi.h(3236)
> 8\VC\PlatformSDK\include\wingdi.h(3237)
> 8\VC\PlatformSDK\include\wingdi.h(3254)
> : error C2146: syntax error : missing ')' before identifier 'lpSize'
> : error C2061: syntax error : identifier 'lpSize'
> 8\VC\PlatformSDK\include\wingdi.h(3255)
> 8\VC\PlatformSDK\include\wingdi.h(3266)
> 8\VC\PlatformSDK\include\wingdi.h(3267)
> 8\VC\PlatformSDK\include\wingdi.h(3489)
> 8\VC\PlatformSDK\include\wingdi.h(3491)
> 8\VC\PlatformSDK\include\wingdi.h(3727)
> 'lpEnhMetaHeader'
> : error C2081: 'LPENHMETAHEADER' : name in formal parameter list illegal
> : error C2061: syntax error : identifier 'lpEnhMetaHeader'
> 8\VC\PlatformSDK\include\wingdi.h(4009)
> 8\VC\PlatformSDK\include\wingdi.h(4011)
> 8\VC\PlatformSDK\include\wingdi.h(4016)
> 8\VC\PlatformSDK\include\wingdi.h(4017)
> 8\VC\PlatformSDK\include\wingdi.h(4018)
> 8\VC\PlatformSDK\include\wingdi.h(4477)
> 8\VC\PlatformSDK\include\wingdi.h(4478)
> 8\VC\PlatformSDK\include\wingdi.h(4531)
> 8\VC\PlatformSDK\include\wingdi.h(4532)
> 8\VC\PlatformSDK\include\wingdi.h(4571)
> 8\VC\PlatformSDK\include\wingdi.h(4572)
> 8\VC\PlatformSDK\include\wingdi.h(4592)
> : fatal error C1003: error count exceeds 100; stopping compilation
> NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
> 8\VC\BIN\c
> l.EXE"' : return code '0x2'
> Stop.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090107/c3c0cb24/attachment-0001.html
