[mapserver-users] MapServer 5.2.1 and AGG/PNG - too thick
linesin the grid
Maxim Savchenko
maxims731 at inbox.ru
Thu Jan 8 04:41:49 EST 2009
Do you know is this option will be available in the next version?
Steve Lime wrote:
> If you're adventurous you could try the dev trunk from svn. It supports
> fractional line widths so
> it's easier to get very fine line work from AGG.
> Steve
>>>> On 1/7/2009 at 12:05 PM, in message
>>>> <1231351502708-2123874.post at n2.nabble.com>,
> Maxim Savchenko <maxims731 at inbox.ru> wrote:
>> It's too heavy way, but it is a way... Thank you for idea but i will not
>> be
>> using it :-) I leave this "as is" or will fallback to the gd driver
>> better.
>> Reinoud Bokhorst wrote:
>>> I experienced the same problem a while ago and reverted to using a
>>> separate mapfile for the graticule using the GD driver. In your 'main'
>>> mapfile you could then create a graticule layer with CONNECTIONTYPE WMS
>>> that connects to a URL using the graticule mapfile (f.ex. something like
>>> this: http://localhost/cgi/mapserv?map=graticule.map&). This way you
>>> still
>>> have one entry point for all your layers.
View this message in context: http://n2.nabble.com/MapServer-5.2.1-and-AGG-PNG---too-thick-lines-in-the-grid-tp2112673p2127104.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
