Fw: Fw: [mapserver-users] error compilation for mapserver 5.2.1
sandric ionut
sandricionut at yahoo.com
Thu Jan 8 05:04:28 EST 2009
----- Forwarded Message ----
To: Tamas Szekeres <szekerest at gmail.com>
Sent: Thursday, January 8, 2009 12:04:00 PM
Subject: Re: Fw: [mapserver-users] error compilation for mapserver 5.2.1
Hi:
I have modified with MSVC_VER = 1400
I have downloaded the swigwin-1.3.37-rc1, which is the newest version. I didn't understood what to modify for SWIG ?
This problem occurs when I try to compile the Mapserver 5.2.1, not the mapscript solely. If I try to compile only the mapscript I get
LINK : fatal error LNK1104: cannot open file '../../mapserver_i.lib' (I think because mapserver is not compiled yet)
Thank you,
Ionut
To: sandric ionut <sandricionut at yahoo.com>
Cc: MapserverList OSGEO <mapserver-users at lists.osgeo.org>
Sent: Thursday, January 8, 2009 11:28:17 AM
We use MSVC_VER=1400 setting with MSVC2005 and SWIG-1-3-33, but I'll also try to compile with a newer version. Does this problem occurs when compiling the csharp stuff solely?
Best regards,
Tamas
2009/1/8 sandric ionut <sandricionut at yahoo.com>
Sorry:
And the nmake.opt file
Hi Tamas:
I have attached the nmake.opt file. I have downloaded the source code for mapserver 5.2.1. from the mapserver website and than I have followed the intructions to compile mapserver
I have tried with both visual studio command promt and vcvars32.bat. I get the same error
Thank you,
Ionut
Cc: mapserver-users at lists.osgeo.org
Sent: Thursday, January 8, 2009 12:42:45 AM
Subject: Re: [mapserver-users] error compilation for mapserver 5.2.1
Hi Ionut,
I'm guessing the library files and the includes you're compiling against might not relate to the same version. Could you provide a diff how you alter nmake.opt when compiling mapserver? Do you use the Visual Studio Command prompt or set up the environment manually (like using vcvars32.bat or something).
Best regards,
Tamas
2009/1/7 sandric ionut <sandricionut at yahoo.com>
Hello:
I try to compile mapserver 5.2.1. using Microsoft Visual Studio 2005. I have made the proper modifications to the nmake.opt file and run the compile command as:
nmake -f makefile.vc charp
After several errors (which I've managed to pass), I've the following error (see bellow)
How can I correct this?
Thank you in advance
Ionut
-DUSE_THREAD -DIGNORE_MISSING_DATA -DENABLE_STDERR_DEBUG -DUSE_
GD_ANTIALIAS -DUSE_ZLIB -DUSE_AGG -DWIN32 -D_WIN32 /c mapraster.c /Fo
mapraster.obj
mapraster.c
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\winnt.h(327) :
warning C4005: 'TEXT' : macro redefinition
h:\kit\mapserver-5.2.1\mapfile.h(123) : see previous definition of 'TEXT
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\windef.h(343)
: error C2059: syntax error : 'constant'
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\windef.h(345)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\windef.h(346)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\windef.h(357)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(98) :
warning C4005: 'ERROR' : macro redefinition
h:\kit\mapserver-5.2.1\mapfile.h(52) : see previous definition of 'ERROR
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(879)
: error C2061: syntax error : identifier 'SIZEL'
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(880)
: error C2061: syntax error : identifier 'szlMillimeters'
: error C2059: syntax error : ';'
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(890)
: error C2061: syntax error : identifier 'szlMicrometers'
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(893)
: error C2059: syntax error : '}'
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(1103)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(1104)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(1105)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(1106)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(1557)
: warning C4005: 'TRANSPARENT' : macro redefinition
h:\kit\mapserver-5.2.1\mapfile.h(130) : see previous definition of 'TRAN
SPARENT'
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(3025)
: error C2146: syntax error : missing ')' before identifier 'lpsize'
: error C2081: 'LPSIZE' : name in formal parameter list illegal
: error C2061: syntax error : identifier 'lpsize'
: error C2059: syntax error : ')'
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(3049)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(3203)
: error C2146: syntax error : missing ')' before identifier 'lpsz'
: error C2061: syntax error : identifier 'lpsz'
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(3204)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(3212)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(3213)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(3227)
: error C2146: syntax error : missing ')' before identifier 'psizl'
: error C2061: syntax error : identifier 'psizl'
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(3228)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(3236)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(3237)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(3254)
: error C2146: syntax error : missing ')' before identifier 'lpSize'
: error C2061: syntax error : identifier 'lpSize'
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(3255)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(3266)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(3267)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(3489)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(3491)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(3727)
: error C2146: syntax error : missing ')' before identifier 'lpEnhMetaHeader'
: error C2081: 'LPENHMETAHEADER' : name in formal parameter list illegal
: error C2061: syntax error : identifier 'lpEnhMetaHeader'
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(4009)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(4011)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(4016)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(4017)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(4018)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(4477)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(4478)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(4531)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(4532)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(4571)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(4572)
C:\Program Files\Microsoft Visual Studio 8\VC\PlatformSDK\include\wingdi.h(4592)
: fatal error C1003: error count exceeds 100; stopping compilation
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio 8\VC\BIN\c
l.EXE"' : return code '0x2'
Stop.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090108/1af63beb/attachment-0001.html
