[mapserver-users] MapServer 5.2.1 and AGG/PNG - too thick linesin
the grid
thomas bonfort
thomas.bonfort at gmail.com
Thu Jan 8 07:08:25 EST 2009
it will be available in the next major release (i.e. 5.4 or 6.0
depending on what it gets called). It will not be in 5.2.2.
regards,
thomas
On Thu, Jan 8, 2009 at 10:41, Maxim Savchenko <maxims731 at inbox.ru> wrote:
> Do you know is this option will be available in the next version?
> Steve Lime wrote:
>> If you're adventurous you could try the dev trunk from svn. It supports
>> fractional line widths so
>> it's easier to get very fine line work from AGG.
>> Steve
>>>>> On 1/7/2009 at 12:05 PM, in message
>>>>> <1231351502708-2123874.post at n2.nabble.com>,
>>> It's too heavy way, but it is a way... Thank you for idea but i will not
>>> be
>>> using it :-) I leave this "as is" or will fallback to the gd driver
>>> better.
>>> Reinoud Bokhorst wrote:
>>>> I experienced the same problem a while ago and reverted to using a
>>>> separate mapfile for the graticule using the GD driver. In your 'main'
>>>> mapfile you could then create a graticule layer with CONNECTIONTYPE WMS
>>>> that connects to a URL using the graticule mapfile (f.ex. something like
>>>> this: http://localhost/cgi/mapserv?map=graticule.map&). This way you
>>>> still
>>>> have one entry point for all your layers.
> View this message in context: http://n2.nabble.com/MapServer-5.2.1-and-AGG-PNG---too-thick-lines-in-the-grid-tp2112673p2127104.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
