[mapserver-users] Mapserver.org sample ...
Christopher Schmidt
crschmidt at metacarta.com
Tue Jan 13 12:35:37 EST 2009
On Tue, Jan 13, 2009 at 02:30:39PM -0300, Paul james wrote:
> Thanks !
> Can you point me some quickstart with openlayer + mapserver + tilecache? I´m
> kind lost on it...
I would recommend first reading:
http://workshops.opengeo.org/openlayers/intro/doc/en/
Which is an excellent introductin to OpenLayers.
After that, get something working as a WMS, then:
http://geoserver.org/display/GEOSDOC/TileCache+Tutorial
Is a good TileCache Tutorial.
-- Chris
> I have a custom app using mapscript + postgis... And I´d like to make a
> version using openlayers and tilecache...
> On Tue, Jan 13, 2009 at 2:03 PM, Christopher Schmidt <
> crschmidt at metacarta.com> wrote:
> > On Tue, Jan 13, 2009 at 12:57:24PM -0300, Paul james wrote:
> > > Thanks Tamas...
> > > Is It possible to use OpenLayers with mapscript?
> > In what way? OpenLayers would typically take over many of the roles that
> > a custom application would -- building your application in Javascript
> > instead of PHP. Depending on what you are doing with mapScript, it may
> > be possibl t simply use MapServer as a CGI instead, or it may be
> > possible to implement what you want such that OpenLayers can ccomplish
> > it.
> > > On Tue, Jan 13, 2009 at 12:47 PM, Tamas Szekeres <szekerest at gmail.com
> > >wrote:
> > > > Paul,
> > > > This kind of functionality requires some client side scripting like
> > > > javascript implemented by OpenLayers in this particular case.
> > > > Best regards,
> > > > Tamas
> > > > 2009/1/13 Paul james <pauljame at gmail.com>
> > > >> Hello guys...
> > > >> Looking at mapserver.org map sample. I´d like to know how can I do
> > > >> something like that ... Can someone point me the right direction to do
> > that?
> > > >> Is it possible to use mapscript c# to do that?
> > > >> Thanks
> > > >> _______________________________________________
> > > >> mapserver-users mailing list
> > > >> mapserver-users at lists.osgeo.org
> > > >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> > Christopher Schmidt
> > MetaCarta
Christopher Schmidt
MetaCarta
