[mapserver-users] GPX format supported?
bean at warbaby.com
bean at warbaby.com
Tue Jan 13 16:21:03 EST 2009
Hi Steve,
Thanks for the rapid reply. I have removed the layers one by one.
They all parse right but this GPX layer.
Curiously if I remove the class statement (including the first end
statement) I get no parse errors but the layer fails to render.
Still puzzled,
bean
>Bean,
>You probably have some other layer that does not have the block ...
>ENDs match up correctly. Try making a mapfile with just the single
>layer below and see if that works, then add another layer and test
>it, and so on until it breaks. Also check the all quoted strings are
>properly terminated.
>No magic here, just take it layer by layer until you find the problem.
>-Steve W
>>LAYER
>> NAME 'GPS'
>> TYPE POINT
>> CONNECTIONTYPE OGR
>> CONNECTION
>>'/Applications/MAMP/d/DATA/NonGrassFiles/GPX/gpsbabel_output.gpx'
>> DATA 'waypoints'
>> STATUS ON
>> DEBUG 5
>> CLASS
>> STYLE
>> SYMBOL 'CIRCLE'
>> SIZE 3
>> OUTLINECOLOR 0 0 0
>> COLOR 106 7 182
>> END
>> END
END
