[mapserver-users] Accessing a different type of raster data type
Roger André
randre at gmail.com
Tue Jan 13 16:39:44 EST 2009
Frank, you rock.
Thanks for the links.
Roger
On Tue, Jan 13, 2009 at 1:17 PM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> Roger André wrote:
>> Hi All,
>> I'm curious if you could give me an idea of the level of effort this would
>> take. I have access to a data service at work that will render an array of
>> values in response to a bbox geographic query. I'd like the ability to
>> create a Mapserver raster Layer that uses this service as a data source, so
>> that I can populate a web map using dynamically generated data, rather than
>> pre-rendering a raster set. How hard would it be to write a new "connector"
>> that could read this data service?
>> Thanks in advance for any advice you can give me,
> Roger,
> It should be reasonable easy to add this as a new GDAL format driver,
> or alternatively as an extension of the existing "WMS" driver which
> has a "minidriver" mechanism to add new web service types beyond
> WMS.
> Some helpful resources:
> * The driver implementation tutorial:
> http://www.gdal.org/gdal_drivertut.html
> * The WMS driver code (see mini drivers for examples of new protocols):
> http://svn.osgeo.org/gdal/trunk/gdal/frmts/wms/
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090113/f69dfa36/attachment.html
