[mapserver-users] newbie: Error in first atttempt to use
postgis with mapserver?
Venkat Rao Tammineni
vtammineni at roulacglobal.com
Thu Jan 15 06:33:35 EST 2009
I think OID column may not be with your table.Can you check that ..
Thanks
Venkat.
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Saka Royban
Sent: Thursday, January 15, 2009 3:36 PM
To: MapServer
Subject: [mapserver-users] newbie: Error in first atttempt to use postgis
with mapserver?
Hi everyone.
i've used workshop material of FOSS4G2007 (PostGIS workshop)to learn postgis
along with its data. but there is a problem
i got this error in first attempt to retrieve data from postgis:
msDrawMap(): Image handling error. Failed to draw layer named
'bc_municipality'. prepare_database(): Query error. Error declaring cursor:
ERROR: column "oid" does not exist LINE 1:
...inary(force_collection(force_2d(the_geom)),'NDR'),OID::text ... ^ With
query string: DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from
bc_municipality WHERE the_geom && setSRID('BOX3D(458426.1
260651.497368421,1943216.4 1373313.90263158)'::BOX3D,
find_srid('','bc_municipality ','the_geom') )
msPOSTGISLayerRetrievePGVersion(): Query error. Error executing POSTGIS
statement (msPOSTGISLayerRetrievePGVersion():select substring(version() from
12 for (position('on' in version()) - 13))
i don't know what causes the problem although it sounds easy.
THX
-----Inline Attachment Follows-----
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090115/cd49b34e/attachment-0001.html
