[mapserver-users] How to develop in Mapserver?
Tamas Szekeres
szekerest at gmail.com
Thu Jan 15 07:58:07 EST 2009
Do you have an example where you'd like to plug your code into the mapserver
codebase, what kind of algorithm you'd like to implement?
The debugging options may be specific to the platform and the
compiler/debugger beilg used. For example you could compile mapserver with
debug info by using MSVC and setting up the debug option in the nmake.opt
file.
Best regards,
Tamas
2009/1/15 LMonge <boommonge at gmail.com>
> Hello
> I want to develop and adapt an algorithm to the source code of MapServer,
> but I don't have idea what tool I need to develop in the mapserver. For
> example: I want to verify step by step that my algorithm run!, verify errors
> in declarations and fuctions, compile my algorithm with the source code of
> mapserver and check my algorithm with the define values of .MAPFILE
> Goal:
> Verify operation of the algorithm with data of the (.MAP) <-- TOOL-->Compile and run the source code of mapserver and my algorithm
> I hope somebody help me!, and can write me some good tips pleasee
> My best regards
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090115/90a1d7f4/attachment-0001.html
