[mapserver-users] Mapserver,RASTER, GDAL & SDE
Russell McOrmond
russell at flora.ca
Thu Jan 15 10:32:11 EST 2009
In tracking why our connections to SDE for Raster wasn't working, I
noticed that the same string for gdal_translate doesn't work eithor with
how we are buildingthings. I know this is a GDAL question and not
mapserver, but I hope folks here may know the magic as this may turn out
to be similar to my iconv.h build problem.
Type of command line I am trying to make work:
gdal_translate "SDE:ndevsde_xdm,5150,sde,username,password,PLANT_XDATA.BIO_CA_PLANT_HARDINESS_2000,RASTER" a.tif
Equivalent in the mapfile:
CONNECTIONTYPE SDE
DATA 'SDE:ndevsde_xdm,5150,sde,username,password,PLANT_XDATA.BIO_CA_PLANT_HARDINESS_2000,RASTER'
I note that mapserver simply makes a call to GDALOpen() for this
connection type, which is why I'm focusing looking at how the GDAL library
is built/etc.
Here is how I'm compiling:
bash-3.00$ sh config.status --recheck
running /bin/sh ./configure --prefix=/server/ndevl18/apache-2.2.9
--with-xerces=/server/ndevl18/apache-2.2.9
--with-sde=/server/ndevl18/arcsde-9.2sp5/sdeexe92/ --with-sde-version=92
--with-oci=yes --with-expat=/server/ndevl18/apache-2.2.9
--with-geos=/server/ndevl18/apache-2.2.9/bin/geos-config
configure: checking whether we should include ESRI SDE support...
checking for main in -lpthread... yes
checking for main in -lsocket... no
checking for main in -ldl... yes
using ESRI SDE from /server/ndevl18/arcsde-9.2sp5/sdeexe92/.
SDE support: yes
After config runs I have a GDALmake.opt file which contains:
# SDE
HAVE_SDE = yes
SDE_LIB = -L/server/ndevl18/arcsde-9.2sp5/sdeexe92//lib -lsde -lpe -lsg -lpthread -ldl
SDE_INC = -I/server/ndevl18/arcsde-9.2sp5/sdeexe92//include
When I build everything and try what I've seen work elsewhere I get:
./apps/gdal_translate
a.tif
ERROR 4:
`SDE:ndevsde_xdm,5150,sde,username,password,PLANT_XDATA.BIO_CA_PLANT_HARDINESS_2000,RASTER'
does not exist in the file system,
and is not recognised as a supported dataset name.
GDALOpen failed - 4
Quick thoughts? Is there something I've thus far been missing?
Should I be asking in the GDAL lists instead?
Note: All this building/testing/etc are on RHEL4 machines. We are trying
to create a build environment where we include the libraries we need, and
are less dependant on the OS library versions/etc.
Russell McOrmond, Internet Consultant: <http://www.flora.ca/>
Please help us tell the Canadian Parliament to protect our property
rights as owners of Information Technology. Sign the petition!
http://digital-copyright.ca/petition/ict/ http://KillBillC61.ca
"The government, lobbied by legacy copyright holders and hardware
manufacturers, can pry control over my camcorder, computer,
home theatre, or portable media player from my cold dead hands!"
