[mapserver-users] Mapserver,RASTER, GDAL & SDE
Frank Warmerdam
warmerdam at pobox.com
Thu Jan 15 11:04:31 EST 2009
Russell,
I have only limited familiarity with the GDAL SDE driver, but I thought
I might mention:
1) If you added the SDE support to your configure after a preliminary
build of GDAL make sure you do a "make clean" in the source tree after
the configure and before rebuilding with SDE.
2) Confirm that you are actually installing and replacing the old libgdal.so.
Check the date, or even use locate to confirm you know which libgdal's exist
on the system.
3) Try "gdalinfo --format sde" to confirm that the SDE driver is built into
the GDAL you are using. It should report a few details about the driver if
it is enabled, otherwise it will report there is no such driver.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
