[mapserver-users] error with OGR in mapfile
Frank Warmerdam
warmerdam at pobox.com
Thu Jan 15 11:08:42 EST 2009
simone.frigerio wrote:
> I want to connect in map file a raster that is present in the
> geodatabase.
> The layer was so written:
> LAYER
> NAME "shadow_exp1"
> TYPE RASTER
> DATA "shadow_exp1"
> TEMPLATE "ttt"
> CONNECTIONTYPE OGR
> CONNECTION "riskcity.mdb"
> METADATA
> "force_imagetype" "jpeg"
> END
> END
> The failure is linked to CONNECTIONTYPE, I suppose. OGR is the
> string to retrieve remote data, but probably for vectorial type.
> Should you indicate me the string to raster connection?
Simone,
GDAL/OGR has no support for rasters in geodatabases so I believe you are
out of luck.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
