[mapserver-users] error with OGR in mapfile
Fawcett, David
David.Fawcett at state.mn.us
Thu Jan 15 12:50:31 EST 2009
Simon,
I believe that in the case of an ESRI Personal Geodatabase (Access db),
the rasters are not actually stored in the database. The data that
creates the image catalog is in the database, but the image files are
actually just stored on the filesystem. If have enough information
about each individual image, you should just be able to pull them into
MapServer using a raster layer.
Once you create a MapServer raster layer to display one of the images to
confirm that this works, you would likely want to create a tileindex
shapefile so you could put all of your images in the same layer.
David.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Frank
Warmerdam
Sent: Thursday, January 15, 2009 10:09 AM
To: simone.frigerio
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] error with OGR in mapfile
simone.frigerio wrote:
> I want to connect in map file a raster that is present in the
> geodatabase.
> The layer was so written:
> LAYER
> NAME "shadow_exp1"
> TYPE RASTER
> DATA "shadow_exp1"
> TEMPLATE "ttt"
> CONNECTIONTYPE OGR
> CONNECTION "riskcity.mdb"
> METADATA
> "force_imagetype" "jpeg"
> END
> END
> The failure is linked to CONNECTIONTYPE, I suppose. OGR is the
> string to retrieve remote data, but probably for vectorial type.
> Should you indicate me the string to raster connection?
Simone,
GDAL/OGR has no support for rasters in geodatabases so I believe you are
out of luck.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
