[mapserver-users] Mapserver --> ESRI sde --> zlib -->core dump
Russell McOrmond
russell at flora.ca
Fri Jan 16 13:29:09 EST 2009
Again, apologies for asking a non-Mapserver question in this forum.
This is a group of people I suspect might have come up against this
problem and a solution.
We're trying to get mapserver to connect to SDE to get RASTER data. I
know that mapserver just uses GDAL to handle this type of connection.
At first I was trying to get this connection to work with GDAL 1.4.4 and
it wasn't connecting, but with GDAL 1.6.0 it connects fine. The command
line gdal_translate from this version can grab data without a problem.
In mapserver I use:
DATA "SDE:dome,5150,sde,username,password,XDM_XDATA.ELV_NA_GEBCO_BATHYMETRY,RASTER"
Mapserver will connect to the server ( GDALOpen() isn't NULL), but I
then get a core dump. With gdb I found that the problem happens when
inflate_fast() in libz is called by inflate_codes() in libsde.
Googling I found this problem being discussed back in 2007
http://forums.esri.com/Thread.asp?c=2&f=1718&t=212867 (Started by Howard
Butler). I see a bug tracking ID, but I can't find that ID anywhere but
in that message (IE: there doesn't seem to be a bug with that ID on
support.esri.com ).
Has anyone in this forum bumped up with this problem and found a
workaround? I'm currently using ArcSDE 9.2sp5 . Is this something that is
known to be fixed in 9.3?
Russell McOrmond, Internet Consultant: <http://www.flora.ca/>
Please help us tell the Canadian Parliament to protect our property
rights as owners of Information Technology. Sign the petition!
http://digital-copyright.ca/petition/ict/ http://KillBillC61.ca
"The government, lobbied by legacy copyright holders and hardware
manufacturers, can pry control over my camcorder, computer,
home theatre, or portable media player from my cold dead hands!"
