[mapserver-users] umn map server requested url not found on	this server error
    vikram_vap
    patilvikram at gmail.com
    Fri Jan 16 12:13:32 PST 2009
Hello ,
        I figure out solution for this problem .As windows service can not
be restarted using apache-restart.bat ,so apache is not updated with new
conf file . So I would say it will be better  use Services console from
windows to restart Ms4w app server.
Also do check if cache is activated on http server before restarting as it
can be one of the reason too.
Thanks ,
Vikram
Newbie in Mapserver
vikram_vap wrote:
> Jeff McKenna wrote:
>> cemre yilmaz wrote:
>>> Hello everybody;
>>> I have installed ms4w on my PC succesfully. I have typed
>>> "http://localhost/" on my web browser and main page of map server
>>> opened. After I  tested if the server is working properly then I have
>>> create a folder called "tfc" in *C:/ms4w/apps*  and I have created a
>>> configuration file in the folder *c:/ms4w/httpd.d* folder called
>>> *httpd_tfc.conf *and I typed;
>>> Alias /tfc/ "/ms4w/apps/tfc/"
>>> <Directory "/ms4w/apps/tfc/">
>>> AllowOverride None
>>> Options Indexes FollowSymLinks Multiviews
>>> Order allow,deny
>>> Allow from all
>>> </Directory>
>>> When I typed "http://localhost/tfc/" on web browser normally  I should
>>> see the empty file but there is a message on the opened page that
>>> "server requested url not found on this server " error 404. What should
>>> be the reason? I don't understand what is wrong. Why server can't find
>>> the folder.
>>> Note: I have restarted the apache server after the configuration file.
>>> Could you please inform me about this problem it is very urgent. Thanks
>>> a lot.
>> Your steps look valid.  I don't have the answer, but if that was me I
>> would try the following:
>> - I might purposely make an error in httpd_tfc.conf (such as have
>> "AllowOverride None1") and open a Command window and execute
>> c:/ms4w/apache-restart.bat .......just to verify that an error is
>> reported and I am modifying the correct Apache
>> - I might also download another MS4W add-on package (such as the
>> "PHP/MapScript Sample Application") and restart apache, and see if I can
>> access it in the web browser
>> _ I would then just copy that add-on folder in /ms4w/apps/ and give the
>> new folder a name, and copy/rename the /ms4w/httpd.d/httpd_gmap.conf
>> file and restart Apache....that process should work if the other add-on
>> application worked in Apache.
>> Happy holidays to all.
>> Jeff McKenna
>> FOSS4G Consulting and Training Services
>> http://www.gatewaygeomatics.com/
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Hello Jeff,
>   I am facing same problem as Cemre . Hey Cemre if you have found solution
> please let me know soon
> Thanks in advance.
> Thanks & Regards,
> vikram
View this message in context: http://n2.nabble.com/umn-map-server-requested-url-not-found-on-this-server-error-tp2092066p2170396.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
More information about the MapServer-users
