[mapserver-users] google tiles
Chad Clabaugh
cclabaugh at centwire.com
Mon Jan 19 13:29:35 EST 2009
Thanks for your reply Roger. The spec for tilemode is at
http://mapserver.org/output/tile_mode.html But Ill definitely look into
TileCache as well.
Sent: Monday, January 19, 2009 12:03 PM
To: Chad Clabaugh
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] google tiles
Hi Chad,
I wasn't aware that "tile" is a valid mode of operation for Mapserver. I
looked on http://mapserver.org/cgi/controls.html and didn't see it
referenced there, but its entirely possible that it exists and that I've
just missed it. In any case, the way I'm familiar with generating google
map tiles is via the use of Tilecache. Tilecache works as in intermediary
between Mapserver and your Google map. It make the appropriate request to
Mapserver for a tile, and then returns the tile to your map. I think this
might be the solution you're looking for, http://tilecache.org/.
Best of luck,
Roger
On Mon, Jan 19, 2009 at 6:50 AM, Chad Clabaugh <cclabaugh at centwire.com>
wrote:
Greetings,
I have been trying to generate google tiles from shapefiles using mapserver.
I have been able to successfully generate maps by calling the url
http://0.0.0.0/cgi-bin/mapserv?map=/srv/www/htdocs/mapserver/coverage.map
<http://0.0.0.0/cgi-bin/mapserv?map=/srv/www/htdocs/mapserver/coverage.map&m
ode=map> &mode=map . but when I attempt to use the url
http://172.18.154.186/cgi-bin/mapserv?map=/srv/www/htdocs/mapserver/coverage
.map
<http://172.18.154.186/cgi-bin/mapserv?map=/srv/www/htdocs/mapserver/coverag
e.map&mode=tile&tile=4+6+4> &mode=tile&tile=4+6+4 I receive only empty
images, regardless of tile specified.
Thanks for any help!
MAP
NAME COVERAGE
STATUS ON
SIZE 1400 900
EXTENT 639000.000000 4535300.000000 689900.000000 4582600.000000
UNITS METERS
SHAPEPATH "shapefiles"
IMAGECOLOR 220 220 220
IMAGETYPE PNG
PROJECTION
"init=epsg:4326"
END
LAYER
NAME CoverageMap
TYPE POLYGON
STATUS DEFAULT
DATA notforchad
CLASS
STYLE
OUTLINECOLOR 255 128 128
COLOR 225 0 0
END
END
END
END
Chad Clabaugh
Technical Support, Engineering
Office: 260.760.6398
Mobile: 260.466.8861
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090119/466fbaa0/attachment.html
